FORUMS Post Processing, Marketing & Presenting Photos HDR Creation
Thread started 14 Sep 2009 (Monday) 10:55
Photomatix and Snow Leopard
brucea
Gallery: 28 photos
Joined Oct 2004
Sep 14, 2009 10:55 |  #1
I have been experiencing problems with Photomatix and Snow Leopard, with batch processing. After batch processing two or three photos in the set, I either get a message saying that Photomatix has run out of memory, or it just terminates with an Apple window opening with the iMac's status (reported to Apple, presumably to help them debug).
I have not seen anything on HDRSoft's web site addressing this.
I am using an iMac with 4 GB of memory and have not had the problem previously. Not fixed after reboot and running only Photomatix. Problem does not occur when I process each photo individually or if the batch contains no more than 2 images to be processed.
kirkt
Sep 14, 2009 11:56 |  #2
Hmmm. I am running Snow Leopard on my Mac Book Pro (4GB RAM) and Photomatix Pro 3.2. What format are the files you are trying to combine? If you go to the Batch dialog window and click on the "Settings" button next to the "Generate HDR image" check box, you will find an option to address processing TIFFs to avoid memory issues (see bottom of attached JPEG). I batch processed 16 TIFFs using the default settings (I did not tonemap) and received no error - I did not check the box to avoid memory problems, trying to recreate your issue.
Hope this helps,
Kirk
Kirk
brucea
Gallery: 28 photos
Joined Oct 2004
Sep 14, 2009 12:07 |  #3
I am working with 3 Canon RAW images at a time. I batch process them with tone mapping and with exposure blending.
As I mentioned, I have not had this problem before upgrading to Snow Leopard, and I do not have the problem when I batch no more than two sets of three RAWs at a time.
While your suggestion is good, I am not working with TIFFs so it is not applicable.
Thanks for your help, though.
kirkt
Sep 14, 2009 12:15 |  #4
No problem - I'll try pushing RAWs through and see if I can recreate your problem.
Kirk
Kirk
kirkt
Sep 14, 2009 12:46 |  #5
Hmmm. I just pushed a sequence of 16 RAW images through (from a 5D) with no problems.
Kirk
brucea
Gallery: 28 photos
Joined Oct 2004
Sep 14, 2009 16:41 |  #6
thanks for trying to duplicate the problem. Don't make yourself nuts. I'm far enough gone for both of us.
brucea
Gallery: 28 photos
Joined Oct 2004
Sep 24, 2009 15:51 |  #7
Thanks for all who considered this problem. Turns out that it was a software issue and HDRSoft have an updated version of Photomatix that cures the memory issues.
Especially kirkt, who tried to duplicate the problem.
brucea
Gallery: 28 photos
Joined Oct 2004
Sep 26, 2009 16:40 |  #8
One more quick addition: I tried the software update and it helps but does not completely fix my issue. HDRSoft has advised that it is best to convert RAWS to TIFFs and work on the TIFFS.
3,283 views & 0 likes for this thread, 2 members have posted to it.
1387 guests, 135 members online
