Thread started 14 Sep 2009 (Monday) 13:48
Switch fell off my 50 1.8 mk I
jblaschke
Gallery: 6 photos
Sep 14, 2009 13:48 |  #1
Title says it all. My EF 50mm 1.8 mk I lens, which I picked up about six months ago in pristine condition for use with infrared photography and walk-around shooting is broken. I was shooting at a party in low-light conditions when suddenly, without warning, the AF/M switch simply dropped off the lens, exposing the gearwork inside. Luckily, I saw it and retrieved it. A close examination showed one of the four plastic prongs that anchor the switch plate into place has snapped. No real way to repair that, since it's so thin. Right now the switch is held in place by a piece of tape, but I'm thinking a tiny spot of glue might be my best course of action. Nobody services this lens anymore, after all, and I switch back and forth from AF and M, meaning the tape gets in the way.
I'm really frustrated by this, since the lens is a gem and instantly became one of my favorites. Amazing how much more appealing a "Nifty 50" becomes with decent build quality. :cry:
Canon 7D | Canon 50D IR modified | Canon EF 70-200mm 2.8 IS L | Canon FD 500mm 8.0 Reflex | Canon EF 85mm 1.8 | Canon EF 50mm 1.8 mk I | Canon EF-S 10-22mm | Tamron 28-75mm f/2.8 | Meade 645 (762mm f/5)
Model Mayhem (external link) | DeviantArt (external link) | Lisa On Location: New Braunfels Photography (external link)
gasrocks
Sep 14, 2009 13:54 |  #2
I'm sure someone will servicve it for you. Might involve dust tape or glue if the part cannot be found. Buy another copy = spare parts.
jblaschke
Gallery: 6 photos
Sep 14, 2009 14:01 as a reply to  @ gasrocks's post |  #3
Gasrocks, I thought about buying a copy for parts, but even the broken ones are in demand. And I'm not at all certain I could successfully remove the switchplate without the 25-year-old plastic prongs breaking anyway.
If I go light on the glue, any future repair that needed to get into that panel could force it without much harm. I'm not about to give this one up. Great little lens.
msowsun
"approx 8mm"
Gallery: 18 photos
Sep 14, 2009 14:33 |  #4
The 50mm 1.8 Mk I AF switch is probably exactly the same as the 28mm 2.8 and 35mm 2.0
Both are still in production and should have parts readily available.
Saint728
Sep 14, 2009 15:01 |  #5
It will probably cost more then the lens is worth new, to get it repaired. I've seen old Canon 50mm f/1.8 lenses with metal mount for sale on craigslist for under $60.00.
Take Care,
Cheers, Patrick
Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS
Click Here To See My Gear
Click here to see my Flickr (external link)
http://www.runryder.co​m/helicopter/gallery/9​019/ (external link)
jblaschke
Gallery: 6 photos
Sep 14, 2009 15:49 as a reply to  @ Saint728's post |  #6
Patrick, you're right, even considering the mk I hasn't been available new since '89 or so.
Msowsun, I hadn't considered that. Will keep an eye open for nonworking versions of those two. I might get lucky!
1,260 views & 0 likes for this thread, 4 members have posted to it.
1008 guests, 107 members online
