Just ordered my 50mm lens, and am wondering what the best 'protective' filter to put on it would be? It would be use both inside and out, with and without flash, mostly for photographing people.
Mal
Sailfish Member 165 posts Joined Apr 2005 Location: Townsville, Australia More info | May 23, 2005 14:57 | #1 Just ordered my 50mm lens, and am wondering what the best 'protective' filter to put on it would be? It would be use both inside and out, with and without flash, mostly for photographing people. Canon 60D | Canon 24mm-70mm f2.8L | Canon EF-S 18mm-55mm IS | Canon EF-S 55mm-250mm IS | Canon 50mm f1.8 MkII | Canon 420EX | Canon 580EX II | flickr
xstrio Member 164 posts Joined Jan 2005 More info | May 23, 2005 15:27 | #2 personally i wouldn`t bother, the glass is well recessed into the plastic housing, and doesn`t really need protecting
fitz Member 36 posts Joined Mar 2005 More info | May 23, 2005 15:32 | #3 i would recommend getting the Sky 1-a filter for protection...the 50mm is a great lens but it is cheap for a reason. i have talked to many people who have dropped it and the filter definitely helped protect the glass. -----------
lomond Goldmember 2,366 posts Joined Apr 2004 Location: Ayrshire, Scotland More info | I wouldn't bother. Cameron........My Images
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | May 23, 2005 16:22 | #5 Get a good lens hood, not a filter. It will do more for you. Skip Douglas
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | May 23, 2005 16:28 | #6 I wouldn't throw money away on a filter for that lens. I wouldn't even buy the lens, I found even after calibration by Canon it can't focus accurately enough. The 50mm F1.4's a much better lens. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
lomond Goldmember 2,366 posts Joined Apr 2004 Location: Ayrshire, Scotland More info | Of course the 1.4 is better , it's four times the price. Cameron........My Images
shiatostorm Goldmember 1,073 posts Joined May 2005 Location: Bristol, UK More info | May 23, 2005 17:04 | #8 well, I normally use a polariser most of the time (outside on the water) so for me its an obvious choice, it also darkens up the sky nicely for you.
lomond Goldmember 2,366 posts Joined Apr 2004 Location: Ayrshire, Scotland More info | shiato storm wrote: but, like the most important piece of rubber and insurance, its always good to know you're protected... Classic. Cameron........My Images
May 23, 2005 23:44 | #10 Thanks for all the feedback. I'd love the f1.4 but its simply not an option. AU$145 vs AU$600+. The 1.8 has to be better than the 18-55 kit lens. Interesting that most people have suggested a filter would degrade the quality? I have no idea it would have such an effect. Makes me want to take the cheap UV off my other lenses? So I'll probably try it without a filter for a while. Canon 60D | Canon 24mm-70mm f2.8L | Canon EF-S 18mm-55mm IS | Canon EF-S 55mm-250mm IS | Canon 50mm f1.8 MkII | Canon 420EX | Canon 580EX II | flickr
lostdoggy King Duffus 4,787 posts Joined Aug 2004 Location: Queens, NY More info | May 24, 2005 01:05 | #11 There was alot of hog wash. If you want to buy a filter buy one as recommended before UV or skylight will work since they don't restrict light. The filter will save you from actually cleaning the lens' glass and its not that expensive of an investment. Look for filters by BW, Hoya, Tiffen and then there are some I just can't remember right now. But those are save bet. And those other guys tell that it degrades the photo, well how about a finger print on the lens. Now you have to clean the lens while the Kodak moment has come and gone. With a filter all you have to do is unscrew and shoot. and that is my 0.02.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | lomond wrote: P.S. I'm missing something here. If you "wouldn't even buy the lens "then whose lens did Canon calibrate. ![]() Ok, i'll fill in the implied words if you can't guess them - "If I were in the position of the person who asked the question...". ie I no longer recommend or use this lens, and i'll be selling mine as soon as I get around to it. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Andy_T Compensating for his small ... sensor 9,860 posts Likes: 5 Joined Jan 2003 Location: Hannover Germany More info | May 24, 2005 03:05 | #13 I use a UV filter and a collapsible rubber lens hood. some cameras, some lenses,
| Latest registered member is Thunderstream 1201 guests, 122 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
