Thread started 15 Sep 2009 (Tuesday) 22:39
BG E2N & AF on a 50D
I'm ­ Sasquatch
Gallery: 44 photos
Sep 15, 2009 22:39 |  #1
I recently bought a 50D and set the camera to focus using the AF button on the rear near my thumb instead of the shutter release button. I had my XSi set up like this and loved it.
I installed a battery grip today and realized that I don't have the AF button on the grip. So, I can't auto focus unless I sprout another finger that will reach the back of the camera. This wasn't an issue with the gripped XSi.
Am I missing an obvious solution? Or, have I done something I shouldn't have done?
I'll do some more searching/reading on the 50D. I'm sure there are some excellent tips on setting it up right here on .net.
Thanks for the help.
Have a wheelie nice day!
Fangs404
Sep 16, 2009 00:25 |  #2
IMAGE: http://i26.tinypic.com/16kxi05.jpg
Is that not it?
[edit]
Nevermind, I think I misunderstood your post.
Canon 50D
Canon Speedlite 430EX II
Canon 17-55mm f/2.8 IS USM | Canon 100mm f/2.8L IS USM macro | Canon 50mm f/1.8 | Sigma 10-20mm f/4.0-5.6
My Flickr (external link)
russkny
Sep 16, 2009 00:34 as a reply to  @ Fangs404's post |  #3
I'm not sure if the XSi grip has a dedicated AF-on button, but I know it's missing on the BG-E2N. The solution is to swap functions of the AF-on and "*" (zoom out or AE lock) buttons in the Custom Functions menu. It's the C.Fn IV-2.
Photo Gear: Sony A7 III | Sony 85mm f/1.4
Lighting: Elinchrom Lights and Modifiers, Einstein 640 Lights
BigBlueDodge
Sep 16, 2009 00:36 |  #4
Here's the deal. While the 50D has the AF-ON button, the battery grip does not. If you want to AF using the battery grip, you need to tell the 50D to switch the AF-On and AEL buttons (the button with the * above it). What this does is move AF from AF-On butto, to your AEL button. Since both the 50D and BG-E2N have an AEL Button, you will be able to AF. To make this work, you need to
1. Change C. FnIV:Operation/Others - AF-ON/AE Lock button Switch - 1:Enable
2. Change C. Fn IV: Operation/Others - Shutter Button/AF-ON button - 3: AE Lock/Metering + AF Start
Once you make these changes, you can use the AEL button to AF on the grip.
David (aka BigBlueDodge)
Gear
J-Guy
Joined Oct 2004
Sep 16, 2009 01:19 |  #5
Serious question here, why not just depress the shutter half-way and AF? What is the advantage to swapping the * button?
My Gear List
jwcdds
Gallery: 1929 photos
Best ofs: 8
Joined Aug 2004
Sep 16, 2009 01:41 |  #6
There's more control to use the AF-On button from the back and only have your main shutter button for activating the shutter (and not AF). It's mostly a preference thing but once you start using it consistently, the AF-On has its advantages.
That said, personally I haven't evolved into using the AF-On button. Much to learn I have. :D
Julian
Rai33
Sep 16, 2009 03:47 |  #7
J-Guy wrote in post #8653181 (external link)
It gives you much better control over focus.
This explains it nicely: http://www.usa.canon.c​om …ArticleAct&arti​cleID=2286 (external link)
Portfolio - Fashion/Beauty (external link)
Portfolio - Kids (external link)
Model Mayhem (external link)
I'm ­ Sasquatch
Gallery: 44 photos
Sep 18, 2009 08:27 |  #8
BigBlueDodge wrote in post #8653037 (external link)
Thanks a million! That did the trick.
4,505 views & 0 likes for this thread, 7 members have posted to it.
1503 guests, 128 members online
