FORUMS Canon Cameras, Lenses & Accessories Canon G-series Digital Cameras
Thread started 17 Sep 2009 (Thursday) 19:44
G10 & ST-E2 Problem
TheFloridaShooter
Sep 17, 2009 19:44 |  #1
I purchased a ST-E2 from a fellow POTN member and it works great on my other DSLR cameras. I have it set on channel 2 and on the A side is a 580EX II and on the B side is a 430EX II. With the camera G10 in TV,AV or auto it will not fire the flashes. Is there a trick I'm missing?
Jon
1Dx MKII | 1Dx | 5D MKIV | 5D MKIII | 5Ds r | 5Ds | 7D MKII | 7D | G16 | G3x | EOS M & M3 | 800 f5.6 | 600 f4 | 400 f2.8 | 300 f2.8 | 200-400 f4 | 100-400 f4.5 - 5.6 II x 2 | 70-200 f2.8 | 14 f2.8 II | 50 f1.2 | 50 1.4 | 85 f1.2 | 135 f2 | 24-70 f2.8 II | 11-24 f4 | 35 f1.4 II | Pentax 645Z | SMC Pentax-DA 645 25mm F4 AL | SMC Pentax-D FA 645 55mm F2.8 AL | Pentax 90mm f/2.8 D FA 645 Macro ED AW SR | SMC Pentax-D FA 645 200mm f/4 IF | SMC Pentax-D FA 645 300mm f/4 ED IF | SMC FA 645 400mm f/5.6 ED IF Lens
gofer
Sep 18, 2009 01:53 |  #2
Jon, I assume you've told the flashes to use channel 2 also?
Steve.
TheFloridaShooter
Sep 18, 2009 07:31 |  #3
gofer Yes to that. I have the 580EX II set on Channel 2 A 430EX II Channel 2 B . I'm going to work on this again later this afternoon. Anyone have any ideas?
gofer
Sep 18, 2009 13:10 as a reply to  @ TheFloridaShooter's post |  #4
Obviously as the ST-E2 works perfectly well with your DSLR it's not rocket science to conclude that the problem lies with your G10 but, as there are no menu driven control for external flash on the G10 (other than those which apply to the internal flash also - which I guess are working OK), I can only suggest that you check the hot shoes of both the G10 and the ST-E2 for a possible poor contact. In other words, is the G10 actually seeing the ST-E2? If it is you should lose the flash symbol on the rear LCD when you fit the ST-E2 and a red flash symbol should appear in its place when you switch the ST-E2 on. Does that happen? Incidentally, I've checked my G10 and ST-E2 with a pair of 580EXII's and they work OK so no reason why yours shouldn't work.
Steve.
lefturn99
Sep 18, 2009 16:23 |  #5
You didn't mention manual mode. Does it fire in manual mode?
If not, go back to basics. Channel 1, everything on A, 2 feet in front of the camera. Then work from there.
Does the G10 have the same custom functions as the 50D an5D MkII for wireless Speedlite control?
Will the 580ex II on camera fire the 430ex II?
6D, 5D Mk III, 60D, EOS M, Gear List
TheFloridaShooter
Sep 18, 2009 20:54 |  #6
Everyone,
I'll have to test these ideas out on Sunday and report back.
Thanks until then .........
Leg@cy
1 post
Nov 01, 2009 07:17 |  #7
Did you ever get anywhere with your issue........ ?
I have a similar, but not the same problem, whereby I have a 430ex (not the Exii) and a ST E2 ....
I can get the flash to work, both on and off the camera in Av/Tv mode (as fill in) , but when I set the camera to Manual, so goes the flash.....
i.e. when I use my DSLR in Manual mode, the flash just indicates the effective range...... via some TTL trickery.... However, on the G10 it doesn't seem to do this and forces me to set the power on the flash manually (both on and off camera
I read somewhere that the G10 is comaptible with the EXii guns.......... is this where my issues are ?
Many thanks in advance...
Phil
ps...... been browsing for a LONG time lol
400D - 28-70mm f/2.8 L :cool: - 18-55mm - 50mm F1.8 -
70-300mm - 430EX & 2 x 550ex flash (all Canon) - ST E2 - Tripod and accessories
1,836 views & 0 likes for this thread
G10 & ST-E2 Problem
Latest registered member is KathKirk33
996 guests, 332 members online
