Thread started 19 Sep 2009 (Saturday) 11:19
Got a new toy! Macro TILT ring.
Mark1
Sep 19, 2009 11:19 |  #1
It is make by the Russian manufacturer Hartblei. And it built like a tank!!! There are adjustable models but they are like $50 more. This one has a fixed 8 degrees of tilt. However you can rotate it to what ever angle you want the plain of focus to be on. There are hard stops every 30 degrees. NO auto focus, NO aperture control. So it is all manual focus, and you have to do the DOF preview trick to hold the aperature when you remove the lens.
Now that I am typing this I realize I have not taken any pictures of the adapter it self. I am off to the Fair so I will upload a shot of the adapter as soon as I can. But here are 2 from the kitchen table. Taken with a 50 1.8. I forget the aperture... I think I set it at f/8.
Headshotzx
Sep 19, 2009 12:17 |  #2
An almond! Now that's nice.
Zexun | Flickr (external link) | YouTube (external link) |
gasrocks
Sep 19, 2009 14:43 |  #3
Is this something that fits between your lens and the camera?
msowsun
"approx 8mm"
Gallery: 18 photos
Sep 19, 2009 15:48 |  #4
I think this is what he has...... http://cgi.ebay.com …0233&_trksid=p3​286.c0.m14 (external link)
IMAGE: http://i10.ebayimg.com/01/i/001/10/f4/e000_12.JPG
IMAGE: http://i.ebayimg.com/08/!BYWEOJQCGk~$(KGrHgoOKiEEjlLmf)k0BKhDP!2uVw~~_12.JPG
gasrocks
Sep 19, 2009 16:04 |  #5
But the image circle of most lenses will not cover the sensor when tilted to much degree.
midnight_rider
"Thrown under the bus."
Sep 19, 2009 16:09 |  #6
gasrocks wrote in post #8672324 (external link)
If you are using an EF lens on a crop camera I do not imagine this would be a problem. FF however it may truly be a concern
I never, Not once claimed to read your post...
gasrocks
Sep 19, 2009 17:17 |  #7
Reason true T/S lenses cost so much is that they have to be able to produce a much larger image circle. I'll have to see some exapmles from this "gimmick?"
Madweasel
Sep 19, 2009 18:16 |  #8
Don't forget that as this is an extension tube the image circle is larger, but focus is short. I don't think the image circle size would be a problem, but limited focusing would be a bit of a pain after a while.
Mark.
KenjiS
"Holy crap its long!"
Gallery: 622 photos
Sep 19, 2009 18:46 |  #9
gasrocks wrote in post #8672632 (external link)
One option might be to use a medium format lens + tilt adapter..i've seen them somewhere..
The larger image circle would help substantially
Deviantart (external link)
gasrocks
Sep 19, 2009 19:36 |  #10
I had owned 3 different medium format lenses and a tilt adapter. That combo works. Of course, I did say "had" = sold them.
Mark1
Sep 19, 2009 20:40 |  #11
The examples are not croped. With EF lens on a crop body there is no problems. But as said above, a FF body will most likly have a problem. When I mount my 28-75, the working distance is about 1-1.5 inches. The 50 is about 5 inches.
Useing it with the 50 with it tilted to shorten DOF
and at 1.8...there is NO dof!!! It it so thin I could not get even one shot that had anything useable.
Mark1
Sep 19, 2009 20:44 |  #12
msowsun wrote in post #8672269 (external link)
That is the same as the one I have. Exceptional build quality! I think it out weighs the 50 by 3X.
MrGreen
Sep 21, 2009 13:18 |  #13
Not to sound too cynical here, but what's the point of this contraption? Other than a tilted extension tube, why would you want to tilt your macro??
My site: www.millionflame.com (external link)
Gear: 7D - Zeikos Grip, Rebel XTi/400D - Opteka Grip, EF 24-105mm f/4L, EF 100mm f/2.8L MACRO, EF 50mm f/1.8 (Nifty Fifty), EF-s 55-250mm (Nifty Two-Fifty), Tokina 11-16mm f/2.8, Σ 150-500mm (Bigmos), Σ 35mm f/1.4, Σ 85mm f/1.4, Feisol CT-3442 CF Tripod, Photo Clam PC-40NS Ball head, 580 EX II Flash
gasrocks
Sep 21, 2009 13:20 |  #14
To put the little bit of DOF you do have where it will do the most good.
MrGreen
Sep 21, 2009 15:00 |  #15
gasrocks wrote in post #8682777 (external link)
Isn't that what the focus ring does? I don't see how it's different.
3,418 views & 0 likes for this thread, 9 members have posted to it.
1067 guests, 104 members online
