Thread started 24 May 2005 (Tuesday) 21:37
Little League
madplower4
Joined Jan 2005
May 24, 2005 21:37 |  #1
I am happy with these shots, but I have to have a 20D and the 70-200 lens!!!! I wish I knew then what I know now about cameras before I bought the 300D. I know it is a good camera, but the focal speed of the 70-200 lens and the focal speed, an ai-servo of the 20D is truly necessary for quality action shots!
Does anyone have a couple of grand that I could have???:D
Gear: If she knew how much I've spent = DIVORCE!!
30D, 50 1.8, 85 1.8, 24-70L, 70-200 2.8is, 1.4X, and a $3 grey card:D
madplower4
Joined Jan 2005
May 24, 2005 21:40 |  #2
sorry about the duplicate, here is the other pic I meant to attach...:confused:
madplower4
Joined Jan 2005
May 24, 2005 21:50 as a reply to  @ madplower4's post |  #3
One last pic of the evening...please critique away! The only way to get bette is to learn how you can improve!!!!
MadJack3
Joined Jan 2005
May 24, 2005 22:38 as a reply to  @ madplower4's post |  #4
Just read this thread... https://photography-on-the.net/forum/showthre​ad.php?t=75302 and buy that 20D and 70-200 IS with confidence.
While you're on that thread why don't you add your little story of getting a flash for your "birthday". :-P :-P :-P
OviV
Joined Oct 2003
May 25, 2005 14:16 |  #5
These are good shots. 1600 ISO was unnecessary though since you were getting seeds of 1/3200 and 1/4000. You will get much less noise with 800 or 400 ISO.
Ovi
5D, 40D, Sigma 12-24mm f/4.5-5.6 EX, Sigma 15MM Fisheye,17-40 L, 24-105 L, 50 1.8, Tamron 28-75 2.8, Sigma 70-200 2.8, 70-300mm f/4-5.6 IS, 100-400 L, 300 F4 L, 580 ex, Sigma 500 Super DG Flash x 2, too much other stuff to list.
pcasciola
POTN SHOPKEEPER
Joined Sep 2004
May 25, 2005 14:33 as a reply to  @ OviV's post |  #6
Like Oviv said, use the lowest ISO you can to eliminate all the noise. 1/3200 is not needed unless you are looking to completely freeze a fast moving ball. I find 1/500 - 1/1000th is plenty to freeze most motion in little league baseball, including the swing of the bat. Try Av mode, start at ISO 100 and bump it up until you get in that range and see how that works out.
Philip Casciola
Pro Camera Gear (external link) - POTN Shop (external link)
Canon 7D, EF 50/1.8, EF 85/1.8, EF 300/4L IS, EF-S 18-55, Tamron 28-75/2.8, EF 70-200/2.8L IS
Sigma 1.4x & 2x, Tamron 1.4x, Gitzo 2220 Explorer, 322RC2 grip
madplower4
Joined Jan 2005
May 25, 2005 19:00 as a reply to  @ pcasciola's post |  #7
Thanks to all for the advice. I did shoot these in AV mode. I honestly thought I was only moving the iso up when the f range would start blinking. I assumed (let me change that), thought that when the blinking occurred, it meant the light was too low. I will continue to practice and thanks again for the advice. You guys are really a big help for us "wannabe's". The greatest gift you can give when someone gives you advice, is to pass it on, and you guys/gals are doing just that. Your help is GREATLY appreciated.
However, it would be appreciated even more if one of you would send me a 20D with a 70-200mm 2.8 lens. I'd appreciate it if they were in like-new condition!!:)
OviV
Joined Oct 2003
May 26, 2005 08:02 |  #8
20D is in the mail. ;)
If the f range is blinking it means that you are in TV mode and the camera can not open up the lens anymore to get the speed you have set. If you are in AV mode what would blink is the speed and you would see it blink if your current apperture would require a speed beyond what the camera can do (1/4000 on the 300D). This is likely what you were seeing due to the high ISO you were using and the 2.8 apperture.
Airedale1
Gallery: 80 photos
Joined Jan 2005
May 26, 2005 16:39 as a reply to  @ madplower4's post |  #9
Yeah, in that last pic he took his eye off the ball too soon.;)
Sony RX10 M4
Canon S90
KLandon
May 22, 2008 13:01 |  #10
I also use the 20d for youth sports...
I think you'll be happy. As for these pictures - the grain is too much. As the others have stated above - I'd go for a 400-800 ISO instead.
Are you shooting for a business or just for fun?
And by the way...
Shooting Manual has worked best for me.
2,198 views & 0 likes for this thread, 6 members have posted to it.
Little League
2760 guests, 167 members online
