Thread started 21 Sep 2009 (Monday) 20:27
Linking Cameras
ferry101
Sep 21, 2009 20:27 |  #1
Im a college student and basketball season is coming around, i go to VCU so games will be huge, im going to try and have one camera shooting on the floor and one to be mounted behind the backboard. I want to know what i will need to have the cameras sync? I also am thinking i might want to shoot strobes later on in the year, is there a pocketwizard or something else i could have both cameras sync and also have strobes fire when i shoot? Thanks alot!
Bodies- 1d Mark II, 50d + Grip
Lenses- 70-200 F/2.8L, 17-35 F/2.8L, 85 F/1.8
Lights- 430 EXII
[URL]KyleLaFerriere.wo​rdpress.com[URL]
FlyingPhotog
Cream of the "Prop"
Sep 21, 2009 20:29 |  #2
Pocket Wizards can accomplish both tasks...
Jay
ferry101
Sep 21, 2009 20:30 |  #3
There are so many though! hahaha i dont know where to start, can someone help me?
Lights- 430 EXII
ferry101
Sep 21, 2009 21:38 |  #4
Any help?
Lights- 430 EXII
ferry101
Sep 22, 2009 00:47 |  #5
Will i just need two transceivers to complete the firing of the cameras at the same time?
Lights- 430 EXII
PacAce
Joined Feb 2003
Sep 22, 2009 06:48 |  #6
ferry101 wrote in post #8686570 (external link)
If you want to fire a remote camera every time you fire your handheld camera, then yes, you will only need two tranceivers or one transmitter and one receiver, depending on the brand of remote you get.
If you are going to have a flash mounted on each camera, then syncing each flash to its respective camera will not be a problem. However, if you are thinking of using one flash or one bank of flashes synced to both cameras, then syncing might be a little more tricky. If set up as described in the above paragraph, i.e. handheld camera firing a remote camera, then you will only be able to sync up the flash to one of the two cameras, but not both. This is because your handheld camera will always fire before your remote camera does. (BTW, you'll need a 3rd remote unit to connect to the remote flash).
If you have a 4th remote unit in your hand and use it to simulataneously trigger the two cameras and the flash, it may be possible to sync the cameras to that single flash but it's going to be iffy. Some shots may be synced but others may not be. A PocketWizard MultiMax configured correctly will increase the syncing success rate but they're relatively expensive, especially if you need to get four units.
...Leo
996 views & 0 likes for this thread, 3 members have posted to it.
Linking Cameras
1029 guests, 129 members online
