Thread started 25 Sep 2009 (Friday) 19:41
Lighting Ratio Help
DarenM
Sep 25, 2009 19:41 |  #1
Can someone tell me if I have the concept in mind correct?
1. Fill light should be set two stops less than main light as a starter
2, So...using L 358 Flash meter I set my ISO on the meter, trip flash and reduce power until I get the f stop i want, say 4.
3. Go to fill light, trip and read with meter, reduce power until i get F 8 (two stops less light than the main light).
4. Now, what do I set the camera at? F4 so I have the depth of field I want on the subject, or, do I read the flash by firing both flashes at the same time and reading with light meter?
Canon 1D MK IV, Canon 1D MK III, Canon 5D, 24-70 2.8L, 70-200 2.8 L IS MK II, 17-40 F4 Canon, 430 EX, Canon A2E, 530EX Canon 1.4 Extender, 580 II, 600EX-RT, ST-E3-RT, (Way too much stuff for an amateur)
jeromego
Sep 25, 2009 20:19 |  #2
interested on this too...subscribing.
Jerome
Canon CPS Member
www.lightsandimages.co​m (external link)
facebook (external link)
sdipirro
Sep 25, 2009 20:58 |  #3
I'm no expert, but I'll take a shot at this. First, a 2:1 or 3:1 ration of key:fill is a good place to start. Now most studio shooting is done at f8 or f11 or even higher f-stops. But if you want to shoot at ISO 100, f4, and 1/200 shutter speed, then you want your meter to read exactly this when both main and fill lights fire. So you'd probably meter the fill light alone first to get a reading at 2-stops lower than your desired aperture. Then add the key light and adjust the power until you get the reading you want to shoot with. You may have a hard time shooting at f4 with two lights, depending on the lights (too much power at even the lowest settings).
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
PacAce
Joined Feb 2003
Sep 25, 2009 21:19 |  #4
DarenM wrote in post #8710360 (external link)
If your main light is at f/4, then your fill should be at f/2 if you want 2 stops less light for fill relative to the main light. f/8 means that the fill is brighter than main by 2 stops.
To determine the shutter speed your camera should be set to, measure the light with both strobes/flashes turned on. The meter should read f/4 or a little over that.
...Leo
TMR ­ Design
Joined Feb 2006
Sep 25, 2009 21:24 |  #5
You're confusing smaller apertures with less light. If you have one light giving you a meter reading of f/8 then decreasing the amount of light by 2 stops would give you a reading of f/4, which is a larger aperture. If the aperture were to be 2 stops smaller (higher number is smaller aperture) that would be f/16 which would require 2 stops more light.
This concept is easily misunderstood but very important for understanding exposure and how it pertains to quantity of light and aperture.
Robert
FullStop ­ Photography
Sep 25, 2009 23:00 as a reply to  @ TMR Design's post |  #6
Some pretty good info in the sticky thread on ratios.
website (external link) · facebook (external link) · tumblr (external link)
vincent_su
Sep 25, 2009 23:12 as a reply to  @ FullStop Photography's post |  #7
The ratio of the fill light is relative to what you trying to achieve. If your metering is f/4 for the main light, set your camera to f/4 and take a pix and chimp to make sure the main light is correct.
I usually start my fill light at half the main light and adjust accordingly depends on the subject and mood. There plenty of guidelines but no set rules.
Vincent
"My dark room is bright and I like it."
5Diii; 24-105 f/4; 100 Macro f/2.8; 17-40 f/4; 70-200 f/4 IS; 100-400 II; TS-E90 and stuff.
TMR ­ Design
Joined Feb 2006
Sep 25, 2009 23:15 |  #8
vincent_su wrote in post #8711341 (external link)
Sorry, but when discussing lighting ratios, chimping shouldn't even come up. Histograms and chimping don't tell you anything about ratios.
Robert
vincent_su
Sep 25, 2009 23:38 |  #9
TMR Design wrote in post #8711353 (external link)
I was answering OP's question about how to setup camera.
The chimp is just to double check if the lighting from main light is correct because I don't have a light meter. Hope that clears this part.
As for the ratio, I've also stated that I start with 1/2 of the main light and adjust accordingly.
Vincent
k_strecker
Sep 25, 2009 23:40 |  #10
AGREEEEED!!! This is so true, and so often overlooked or forgotten or dismissed.
TMR ­ Design
Joined Feb 2006
Sep 25, 2009 23:43 |  #11
vincent_su wrote in post #8711436 (external link)
If you don't have a light meter then how are you adjusting? Half the power of the main light only means something if you can meter it.
Robert
vincent_su
Sep 25, 2009 23:50 as a reply to  @ TMR Design's post |  #12
Here is how I do it. I start with settin my camera in M mode, pick an aperture that can cover the focus of my subject, set the ISO, usually 100, then I use 1/250 SS for a test shot. I have my main light starts at 1/4 power and look at the pix and chimp just to make sure.
Then, I would fine tune between the aperture and light output. Once the main light output is what I want, I set the fill light at 1/2 the power of my main light.
This sequence has worked well for me for head shots and product shots.
If there's an easier way, I'll be more than happy to learn.
Vincent
jeromego
Sep 25, 2009 23:55 |  #13
vincent_su wrote in post #8711496 (external link)
Easier way is to have a light meter when talking about ratio. I totally agree with Robert.
Jerome
Canon CPS Member
TMR ­ Design
Joined Feb 2006
Sep 25, 2009 23:55 |  #14
You're missing the point. The OP wants to know how to meter and set ratios. What you're doing is guessing and you have no way of knowing what the ratio is between main and fill. The power levels are meaningless. I'm not saying that you're not getting the results you want but you're not establishing ratios based on anything more than guesswork.
Robert
airfrogusmc
Gallery: 179 photos
Sep 25, 2009 23:58 |  #15
TMR Design wrote in post #8711523 (external link)
You are SO right Robert. Chimping your way there is not the right way to teach ratios or learn them.
3,504 views & 0 likes for this thread, 12 members have posted to it.
Lighting Ratio Help
1549 guests, 135 members online
