Moooney Senior Member 641 posts Likes: 7 Joined Feb 2009 More info | Sep 26, 2009 10:14 | #1 i dismissed this shot after i first took it, but i revisited a few weeks later and it grew on me a little. this bridge is local, so any suggestions on a better perspective would be appreciated, as well as any thoughts on processing. was my first impression correct - should this have stayed in the trash bin? thanks for looking! 5dmk ii / 35mm f/1.4 L / Σ 85mm f/1.4 / 135mm f/2 L / 430 EX II flickr
Sep 26, 2009 10:16 | #2 i don't know if it really matters, but it was handheld 1/15sec @ 20mm f/4 iso 1600 5dmk ii / 35mm f/1.4 L / Σ 85mm f/1.4 / 135mm f/2 L / 430 EX II flickr
Fastfwd13 Senior Member 491 posts Joined Dec 2007 Location: Canada, Montreal More info | Sep 26, 2009 10:18 | #3 If you are going for a feeling of going towards depression then it's just right. I would have removed the whole sky from the crop since it adds nothing to the picture
Sep 26, 2009 10:23 | #4 i try to frame in camera as much as possible, and i think i kind of kept some sky to balance the extensive foreground a bit. i will look into a crop after a few more comments, but i think if i take out the sky, i would probably take out an equal amount of foreground, since it isn't very intersting, either. this might leave me with an almost square crop. any thoughts on this idea? 5dmk ii / 35mm f/1.4 L / Σ 85mm f/1.4 / 135mm f/2 L / 430 EX II flickr
joedlh Cream of the Crop 5,511 posts Gallery: 52 photos Likes: 684 Joined Dec 2007 Location: Long Island, NY, N. America, Sol III, Orion Spur, Milky Way, Local Group, Virgo Cluster, Laniakea. More info | Sep 26, 2009 10:28 | #5 I can see no obvious flaws. It's underexposed and the sky is noisy. However, it really depends on what you were going for. Underexposure is often useful. Noise or "grain" is often added to an image for effect. The perspective is good: diagonal can be more dramatic than dead on. Joe
Fastfwd13 Senior Member 491 posts Joined Dec 2007 Location: Canada, Montreal More info | Sep 26, 2009 10:28 | #6 Can't help you much there. Just was saying was I was thinking as I saw the pic. I myself have a big problem with choosing where to crop and what size to crop for(laptop wallpaper, 8x10, 13x19?)
Sep 26, 2009 10:35 | #7 joedlh wrote in post #8713128 I can see no obvious flaws. It's underexposed and the sky is noisy. However, it really depends on what you were going for. Underexposure is often useful. Noise or "grain" is often added to an image for effect. The perspective is good: diagonal can be more dramatic than dead on. one thing i don't understand about exposure yet is how if shooting in low light, the camera metering will try generally to expose as if it were daytime. is anything less than that considered underexposed? here it was almost dark when i shot, so i just did all i could do to get as much light handheld as possible. the picture resembles how the bridge appeared at that time of day. 5dmk ii / 35mm f/1.4 L / Σ 85mm f/1.4 / 135mm f/2 L / 430 EX II flickr
joedlh Cream of the Crop 5,511 posts Gallery: 52 photos Likes: 684 Joined Dec 2007 Location: Long Island, NY, N. America, Sol III, Orion Spur, Milky Way, Local Group, Virgo Cluster, Laniakea. More info | Sep 26, 2009 10:57 | #8 Moooney wrote in post #8713163 one thing i don't understand about exposure yet is how if shooting in low light, the camera metering will try generally to expose as if it were daytime. is anything less than that considered underexposed? here it was almost dark when i shot, so i just did all i could do to get as much light handheld as possible. the picture resembles how the bridge appeared at that time of day. Camera meters are designed to render all scenes as if they were 18% gray. Your scene was darker than this. So your meter tried to lighten it up. Experience will teach you to evaluate the setting and determine when it requires under- or over-exposure to give you what you want. It looks like you're well on your way to appreciating that. If of course relies on you taking control from the camera and making some exposure decisions yourself. That's one sign of an experienced photographer. Joe
Sep 26, 2009 14:04 | #9 joedlh wrote in post #8713251 Camera meters are designed to render all scenes as if they were 18% gray. Your scene was darker than this. So your meter tried to lighten it up. Experience will teach you to evaluate the setting and determine when it requires under- or over-exposure to give you what you want. It looks like you're well on your way to appreciating that. If of course relies on you taking control from the camera and making some exposure decisions yourself. That's one sign of an experienced photographer. thanks for clearing this up. metering wasn't an issue with this shot--i shot this in manual to get as much light in as possible, then even bumped the exposure in post--i was just asking out of general curiosity. 5dmk ii / 35mm f/1.4 L / Σ 85mm f/1.4 / 135mm f/2 L / 430 EX II flickr
jgrussell Looking around nervously 18,758 posts Likes: 14 Joined May 2008 Location: NJ USA More info | Sep 26, 2009 17:47 | #10 Lose as much of the noise as possible, brighten it up. -- jgr
Sep 26, 2009 19:01 | #11 jgrussell wrote in post #8714826 Lose as much of the noise as possible, brighten it up. what did you do to remove the noise so effectively? you must have applied some sort of mast, eh? 5dmk ii / 35mm f/1.4 L / Σ 85mm f/1.4 / 135mm f/2 L / 430 EX II flickr
| Latest registered member is Monkeytoes 1353 guests, 176 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
