Thread started 26 Sep 2009 (Saturday) 20:21
POLL: "Focus/Recompose... or Select A Point... or.. OTHER"
Focus and Recompose using center point exclusively (feel free to elaborate).
78
51.3%
Select focus point based on are of interest (feel free to elaborate)
66
43.4%
Secret method that you now have to share with us.
8
5.3%
152 voters, 152 votes given (1 choice only choices can be voted per member)). VOTING IS FOR MEMBERS ONLY.
BROWSE ALL POLLS
Focus and Recompose.... or Choose a Focus Point?
Kristy
Gallery: 31 photos
Location: A dream world where nothing is what it seems.
Sep 26, 2009 20:21 |  #1
Hey....
What is the general consesus...
Focus and Recompose... thus risking moving off plane and having an oof image....
or...
Choose an outer focus point that lands where you desire.... and risk the fact that the sensor may not strong enough for acurate focusing... thus having an oof image..
or.... Is there some secret method that no one is sharing about.>?
Life is not measured by the number of breaths we take,but by the moments that take our breath away.
~George Carlin
Kristy :D 5D MkIII, 24-70 / f2.8 L, 2 AB800's, and some modifiers.
My Website Page (external link)
mike_d
Sep 26, 2009 20:24 |  #2
I mostly use center point focus and recompose. If I'm so close (running up against minimum focus distance) or using such a big aperture that doing that could be a problem, I'll just manually focus after I've composed.
Roy ­ G. ­ Biv
Sep 26, 2009 20:27 |  #3
If I have the time for the shot, I use a different focus point. If it is quick, I use center focus and recompose (I also bump up the aperature a bit)
RDKirk
Adorama says I'm "packed."
Joined May 2004
Sep 26, 2009 21:09 |  #4
Focusing to me is something too basic to clutter, so I use only the center point--no futzing--and recompose as necessary. The only times it matters is when shooting with a very fast lens (faster than 1.8 ) at a short distance, in which case I'd be focusing manually.
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Sep 26, 2009 21:27 |  #5
Used to focus and recompose, but that was an iffy proposition because of the obvious "are you sure that that is the same distance as the subject" issues. But with the 5D Old School, I found no comfortable way to quickly choose the focus point.
With the 5D Tech II, the focus point selector is on the little thumb button, that I can get to without taking my eye off the viewfinder. And all you have to do is point it in the direction you want, rather than scrolling through the focus points, over shooting, scrolling back, over shooting again, getting the one you want, and by that time the subject has hailed a cab and gone home.
Much better implementation in the Mk II, so now my shooting has changed for the better. Much fewer missed focus shots than the recompose method.
If that had been the only upgrade, the Mark II was worth it.
Rad
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
mike_d
Sep 26, 2009 21:40 |  #6
Radtech1 wrote in post #8715668 (external link)
Rad
I have a 5D (not MkII) and it works as you describe the MkII. The button can be pushed in any one of 8 directions to jump to the desired focus point or pushed straight in to toggle between single/multi point modes.
ShadowVlican
Sep 26, 2009 23:23 |  #7
i select the closest focus point (easy to do on the 50D)
50D | EF-S 18-200mm f/3.5-5.6 IS | flickr (external link)
The ­ Moose
Sep 26, 2009 23:33 |  #8
I choose wherever I want because the 1D2 is so strong in every area.
Radtech1
Joined Jun 2003
Sep 26, 2009 23:35 |  #9
mike_d wrote in post #8715716 (external link)
You are right, it is there. I honestly don't know why I never used it like that. Perhaps slightly different ergonomics (smaller?), or, more likely, I never associated that function with that button.
:o
FlyingPhotog
Cream of the "Prop"
Sep 26, 2009 23:38 |  #10
Moving Objects: Center Point + Crop In Post if I want it off center
Static Objects (Average to Deep DOF): Center Focus Point + Recompose
Static Objects (Shallow DOF): Off Center Focus Point
At razor-thin DOF, Focus and Recompose can yield OOF shots.
Jay
RDKirk
Joined May 2004
Sep 27, 2009 12:44 as a reply to  @ FlyingPhotog's post |  #11
BTW, here is a comparison of focus/compose with using an off-center point, 100mm focal length, six foot subject distance, f/2.8.
This shows the visible tilt of the focal plane with focus/recompose (look at the hairline), but the focus on the right eye of the manikin is still well within the depth of field even at large enlargements.
Recomposed: http://www.flickr.com/​photos/rdkirk/39085146​78 (external link)
Not recomposed: http://www.flickr.com/​photos/rdkirk/39077390​55 (external link)
SOK
Sep 27, 2009 19:23 as a reply to  @ RDKirk's post |  #12
I try to keep things simple by shooting exclusively at F/22.
:D
I kid. Select focus point for me - easy on the 50D.
Steve
SOK Images - Wedding and Event Photography Gold Coast (external link)
DAMphyne
"the more I post, the less accurate..."
Joined Feb 2003
Sep 27, 2009 21:19 |  #13
You can "set" where the camera focuses?
Man, I gotta read that manual.
David
Digital set me free
"Welcome Seeker! Now, don't feel alone here in the New Age, because there's a seeker born every minute.";)
www.damphyne.com (external link)
yogestee
Sep 27, 2009 21:22 as a reply to  @ DAMphyne's post |  #14
Focus point either bang on the subject and if I can't get the focus point bang on I manually focus ignoring the focus point..
Jurgen
dustyporch
Sep 28, 2009 10:27 |  #15
I said I have a secret method, but I don't... the true answer is I use both methods depending on the situation.
On the XTi, the centre point is more accurate, so I tend to use the focus/recompose method by default. However, if the light is decent and the DOF is large, then i will use the edge points.
The other method I use is to shoot with the centre point, and then crop the photo in post to get the composition I want.
My photos on Flickr... (external link)
9,940 views & 0 likes for this thread, 35 members have posted to it.
2785 guests, 132 members online
