Bodog wrote:
Compare the turns necessary to move your 28-105 from close focus to infinity to the turns necessary to move the macro the same distance. I think that will answer your question.
the 28-105 turns about 100 degrees and the 100 Macro turns a little under 180 degrees. I understand that one travels more than the other,,, what I don't understand is why the 100 macro travesl significantly slower in low light conditions and super fast in bright environments. Its not a problem with searching, its a problem with the speed at which the focusing mechanism travels as seen through the distance scale window.
Dr. David de la Llata
_____________
Canon 20D
BG-E2 Battery Grip
Canon SpeedLite 430 EX
Canon EF 1.4X II
Canon EF-S 10-22mm F/3.5-4.5 USM
Canon EF 50mm F/1.4 USM
Canon EF 100mm F/2.8 MACRO USM
Canon EF 24-70mm F/2.8 L USM
Canon EF 70-200mm F/2.8 L USM
Olympus C-2020 (for infrared work)
