Thread started 27 Sep 2009 (Sunday) 14:04
Outdoor family portrait - Could use suggestions
sdipirro
Sep 27, 2009 14:04 |  #1
So I've been planning to do this family portrait for some friends of mine. This is a family of four that couldn't be more white/blond. I was planning to shoot them in my studio with darker backgrounds, but they just threw me a curve and said they'd kind of like it done outside. With very little experience at this sort of thing, I'm looking for suggestions.
I have one 580EX flash with a PC port so I can use it off camera if I want. I can use this flash with my 22" Kacey beauty dish or 24"x24" Lastolite Ezybox and PWs off camera. I also have the Lumiquest ProMax System and large softbox that attach directly to the flash on camera. I have a couple of reflectors I can use as well. I'm not even against the idea of picking up a second speedlight. I've been looking for an excuse. But if I can do something nice with what I have, all the better.
I think I'll have some flexibility about time of day and setting. So I won't be forced to do this in direct sunlight at noon or anything like that. They're probably going to ask me how I want to do it. Since I'm used to being able to control everything in the studio, all suggestions for this type of shot are welcome!
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
bobbyz
Sep 27, 2009 14:24 |  #2
I though you had studio lights? I will pick some battery power for them or someplace where power outlet is available, like in their backyard.
Regarding hot shoe flash option, look at this guy's shot. I think they turned out pretty well.
https://photography-on-the.net/forum/showthre​ad.php?t=754422
Fuji XT-1, 18-55mm
Marloon
Sep 27, 2009 14:38 as a reply to  @ bobbyz's post |  #3
if you have an assistant, use a reflector instead.
I'm MARLON
Former Canon Platinum CPS member
5DII • 24L • 35L • 50L • 85L • 135L • 200LIS
Wordpress Blog (external link)Youtube Channel (external link)Twitter (external link)Gear List (external link)
sdipirro
Sep 28, 2009 21:31 |  #4
bobbyz wrote in post #8719075 (external link)
Those are great shots. I'd be happy with something similar, and it seems like I should be able to do it with equipment I have. I don't have a shoot-thru umbrella, but I would think a softbox would give me something similar. I guess it's an option to use my studio lights outside, but I wasn't planning on that. I was thinking "strobist" and reflectors for this.
mattograph
"God bless the new meds"
Sep 28, 2009 21:56 |  #5
How big is the octa?
Look at the first pic in bobbyz's callout. Dad got punked on the light -- he's measurably darker and features harder shadows. Why? Cause hes farther from the light, which makes it harder as its apparent size is smaller. Its not a bad pic, but the effect is noticeable if you are looking.
With a family of 4, you can group them tighter. But to account for the falloff (remember, light closer in falls off faster) you're gonna need a big source to get something nice and soft, while getting it farther away to control the fall.
Or try something nutty, like a white bedsheet as a reflector. Doesn't get much bigger than that - at least not for 5 bucks.
This space for rent.
bobbyz
Sep 29, 2009 08:54 |  #6
mattograph wrote in post #8724428 (external link)
Sorry to hijack OP's thread but how to hold/mount the bed sheet and that too outside and god forbid if it is a bit windy. Would be nice to know the little details for us rookies.
Fuji XT-1, 18-55mm
Dermit
Joined Nov 2005
Sep 29, 2009 09:15 |  #7
One thing very important to take note of in these example shots linked to here is that there is no direct sunlight hitting anywhere in the shot. It is all open shade. This is not always easy to find, but when you can, and the setting is great like in these shots, then you are golden. All you need is a little directional light from an added light source like done here so it is not flat and you are good to go.
If you run into a setting where there will be a higher dynamic range of light because there is direct sunlight hitting anywhere in the shot then you will have to try and balance the artificial light power with the sunlight, a much trickier scenario, especially with one light, but it can be done.
5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
http://www.pixelcraftp​hoto.com (external link)
mattograph
Sep 29, 2009 09:24 |  #8
bobbyz wrote in post #8726095 (external link)
Only way to do it either put it on a frame, or have someone hold it. (two people.) You might able to stake it between two pieces of rebar.
I am getting a little out there.....:)
sdipirro
Sep 30, 2009 13:06 |  #9
Well, assuming I can find a spot with no direct sunlight and want to setup a single directional light, the easiest thing for me to do is use the 580EX off-camera with a modifier I already have with hotshoe adapters, like the 22" beauty dish or 24"x24" Ezybox softbox. While not very big light sources, I could use a reflector to bounce some of the light back for fill. Is this worth considering, or should I instead plan on dragging a strobe outside with a bigger modifier, like the Photoflex 5' octa or 39" Elinchom deep octa?
1,671 views & 0 likes for this thread, 5 members have posted to it.
1700 guests, 139 members online
