Thread started 27 May 2005 (Friday) 12:57
If I choose 20D body only, what lens?
busyone
May 27, 2005 12:57 |  #1
I am contemplating getting the 20D body only instead of the kit. I own no other canon or canon-compatible lenses yet.
If I go the body only route, any suggestions on 1 or 2 basic lenses?
I shoot mostly people and landscapes. Will use both indoors and outdoors.
5D Mk II, 24-70 2.8L, 70-200 2.8L, 35mm 1.2, 50mm 1.4, 580 EX
Jon
Joined Jun 2004
May 27, 2005 13:11 |  #2
Looked at the Top 10 Recommended Lenses Sticky?
Jon
Cocker Spaniels
cdhender
Joined Oct 2004
May 27, 2005 13:15 |  #3
Budget?
Chris
lordjim
May 27, 2005 13:16 as a reply to  @ Jon's post |  #4
I would recommend that you rather get the kit with the 18-55 EF-S. The lens is cheap, not bad and can always help until you can get a nicer wide angle lens. Then, I would probably add the 24-70L (or a cheap alternative such as the Tamron 28-75) and one of the 70-200L (the cheapest will be the 70-200F4L). Well, unless you need a good wide angle lens first.
/Alex (aka Lordjim)
busyone
May 27, 2005 14:01 |  #5
Thanks for the recos. I will look into all of them.
jfred
Joined Jan 2005
May 27, 2005 16:47 |  #6
50mm f1.8 is a great little lens, and often overlooked
the tamron 28-75 is usually my "walk around lens", but is a little bit heavy
both are pretty good for both people and landscapes. I wouldn't part with either!
Canon EOS 20D, 580ex, MR-14, 10-22, 50mm f1.8, 100mm f2.8 macro, 70-200mm f4L
Tamron 28-75 f2.8
deedas
May 27, 2005 21:24 |  #7
Tamron 28-75 for sure. :) I love that lens.
Set up: Canon EOS 20D, Canon 50mm f/1.8 II, Tamron 28-75mm f/2.8, Canon 70-200mm f/4L, Sigma 10-20mm F/4-5.6, Canon 420EX Speedlite TTL, Battery Grip, 3GB worth of CF, Tamrac CyberPack 9, P.O.T.N. Op-Tech Strap.
Wish List: Sigma 150mm f/2.8 EX, Canon 85mm f/1.8 USM, Canon 1.4x TC, Giottos MT-8170.
lancea
Joined Jan 2005
May 29, 2005 01:00 |  #8
Hi busyone. I'd also recommend the kit lens as very good value. If you have the budget, the 17-85 EF-S would be a better option. While it wouldn't be described as an indoor lens, Image Stabilisation and the 20D's low-noise high ISO capability mean it will often be usable indoors without flash.
A 50mm 1.8 would give you a sharp low-light lens at an excellent price, but it wouldn't be suitable for landscapes.
Olympus C-50 Zoom; Canon PowerShot G9; EOS 20D; EOS 5D Mark II
Canon EF-S 10-22; EF-S 18-55; EF 17-40 f/4L; EF 24-105 f/4[COLOR=red]L; EF 70-200 f/4L
Mike ­ H
Joined Jan 2004
May 29, 2005 01:26 as a reply to  @ lancea's post |  #9
The budget will be a big factor in deciding what to do, but if you can swing it, consider the 17-40/4L and 70-200/4L combination. For the uses you've described, this is a great combination. The only thing you would lack is the ability to do low level, ambient light work. If you needed the latter capability, there are lenses that will get you there; which to get will depend on the distances to your subjects and how much of the frame you want them to fill.
Mike H
lostdoggy
King Duffus
Joined Aug 2004
May 29, 2005 01:34 |  #10
On a Budget get the Kit lens and the 55-200
Deep Pocket get the EF-S 17-85 IS (personally I don't like this lens because its a EF-S) and the EF 70-200 f/2.8 L IS
and since these are not lenses 1.4x and 2.0x convertors.
RbrtPtikLeoSeny
My love, my baby
May 29, 2005 12:33 |  #11
The tamron 28-75 f/2.8 lens is a kick butt walk around lens. Then there's the fast, sharp, amazing 70-200mm f/4L lens good for portrait, exceptional for sports, decent for large animal photography. Ummmmmm I've always thought the 100mm f/2.8 macro would be a good lens too. Good all around lens... macro photography, portrait, large animals, good walk around lens. All under 600 bucks.
mdm
May 29, 2005 12:37 |  #12
I agree on getting the kit lens. Then you can take your time and research whats best for you. Don't get in any hurry you'll get plenty of helpful info from this site.
Lesmac
Joined Jun 2003
May 29, 2005 13:50 |  #13
I'd start with the kit lens, then progress possibly to the 17-40 F4L, if you are shooting landscapes, I'd also consider filters (polarizer, grads), possibly a tripod, and most definitely a hot-shoe spirit level (around $10)
Hope this helps
Les
http://lesmclean.photo​blink.com/ (external link)
Canon 1DS MKIII,7D, 85 1.2L, 24 F1.4L, 135 F2L, 200mm F2.8L,50mm F1.4, 120-300 F2.8, 12-24mm f 4.5
http://www.lesmclean.c​o.uk/ (external link)
Concentrate on equipment and you'll take technically good photographs. Concentrate on seeing the light's magic colours and your images will stir the soul. - Jack Dykinga
luckyart60
Joined Nov 2003
May 29, 2005 13:58 |  #14
I spent many hours trying to choose the right lens to buy for my needs. I think that I got it right check my lens etc
John A Thompson
http://www.pbase.com/l​uckyjon/birds_of_qatar (external link)
kenyc
May 29, 2005 15:22 |  #15
I bought the 20D kit with the EFS 17-85 is lens and it's a darn fine lens.
KAC
Kenny A. Chaffin
2,744 views & 0 likes for this thread, 15 members have posted to it.
1871 guests, 108 members online
