Thread started 01 Oct 2009 (Thursday) 18:42
Which bubble level to believe?
tvphotog
Oct 01, 2009 18:42 |  #1
I've got an RRS lever QR with a bubble spirit level built in on the flat face. With my 5D2 attached via an RRS L bracket, I put a standard plastic 2-D bubble level in the hot shoe. They read differently.
As the L bracket is closer to the plate than the hotshoe level, I suspect that's the accurate one. But is it?
Jay
Ireland in Word and Image (external link) Jay Ben Images (external link)5D IV | 5DS/R | Sony RX100 V | 24-105L | 100-400 IIL | 16-35 f/2.8 IIL | 24 T/S f /3.5L II | 17 T/S f/4L | 50mm f/1.2L | 35mm f/1.4L | 70-200 f/2.8L II | 580 EX II | 600 EX-RT | Feisol 3441T/Markins Q3T lever QR | Gitzo 3542L Markins Qi20 BV-22 | Gitzo 5561T RRS MH-02
Saint728
Oct 01, 2009 19:16 |  #2
It really only matters what the one on the camera says as it is what your trying to get level. I would go with the level on the hot shoe.
Take Care,
Cheers, Patrick
Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS
Click Here To See My Gear
Click here to see my Flickr (external link)
http://www.runryder.co​m/helicopter/gallery/9​019/ (external link)
Jon
Joined Jun 2004
Oct 01, 2009 19:22 |  #3
Try leveling with the hot shoe level and then reversing that (without moving the camera) and see if it reads the same.
Jon
Cocker Spaniels
Quad
Joined Nov 2005
Oct 01, 2009 19:50 |  #4
I have found the hot shoe levels have too much play in them to be accurate. Check the head level with a quality level to see if it is accurate.
tvphotog
Oct 01, 2009 20:54 |  #5
Quad wrote in post #8744023 (external link)
I think that's correct. The hotshoe was never made to be a level spot on the camera, just to hold a light.
I leveled the RRS QR without the camera in it, then checked it with a carpenter's level...dead on. Then I put the plastic bubble level onto the QR...dead center in both dimensions.
It's clear that the hotshoe is off level.
Jay
tgara
Oct 01, 2009 21:49 |  #6
tvphotog wrote in post #8744355 (external link)
Thanks Jay. Good for everyone to know not to trust the hotshoe as place to level your camera.
EOS 5D Mark III
EOS Rebel SL1
Full Gear List
Curtis ­ N
Master Flasher
Oct 01, 2009 22:14 |  #7
I've never understood the idea of a hotshoe level.
You look through the viewfinder and you level the horizon across the frame. If you can't tell it's off kilter then, you won't be able to tell in the picture either.
gcflora
"I'm not normal"
Oct 01, 2009 22:21 |  #8
Curtis N wrote in post #8744797 (external link)
'Horizons' are not always level in the viewfinder. If you're one of the people who like receding coastlines (for e.g.) to be level then *shrug*
Craig
http://www.australimag​e.com.au (external link)
Saint728
Oct 01, 2009 22:38 |  #9
Is it really that important to get your camera perfectly level then take a picture or is it more important to take the picture then fix horizon in PP? Its easier to just eyeball the horizon and snap away.
Take Care,
Cheers, Patrick
ed ­ rader
"I am not the final word"
Oct 01, 2009 22:41 |  #10
Saint728 wrote in post #8744908 (external link)
Take Care,
Cheers, Patrick
i'm still off by a degree or so when eyeballing. my hotshoe level gets me close enough when i remember to use it :D.
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
Blue ­ S2
Joined Aug 2004
Oct 01, 2009 22:51 |  #11
Level does make a difference in architecture and panoramas. Often my entire rig can be level, but depending what lens I shoot a panorama with, the camera can be off level somewhat due to the weight in portrait orientation. (360 pano setup so the camera is "hung" over the center and not fixed to the level base) I will use a hotshoe level in both orientations, and then take additional readings from the mount. At least with my rig, I find the tripod level, clamp levels, and the hotshoe level, will be pretty close to eachother once everything is set.
Canon 5DmkII / Canon 5D / LifePixel IR 350D / L-glass
Brightscreen Screens & Mags / ReallyRightStuff gear / Singh-Ray filters
Read My Blog!! (external link) -- Visit My Website! : Ancient City Photography (external link)
Wilt
Oct 01, 2009 23:31 |  #12
Sometimes the 'horizon' is a slope of a mountain, and that is not level.
SkipD
Joined Dec 2002
Oct 02, 2009 08:17 |  #13
You can easily test any spirit level that you're trying to use with your camera.
Suspend a plumb bob (or a home-made equivalent) so that the line (string) is in your test scene. Level the camera as accurately as possible with the spirit level. Position the camera so that the plumb bob line is near one end or the other of the image. Make a test exposure. Now, examine the image (on a computer, not the camera's tiny display) and see if the plumb bob line is parallel to the side of the image.
Do the above for each spirit level setup that you have and see what works best for you.
Skip Douglas
Lowner
"I'm the original idiot"
Oct 02, 2009 10:16 |  #14
That trick will also teach you a lot about the viewfinder coverage.
Richard
bunyarra
Gallery: 6 photos
Joined Feb 2006
Oct 03, 2009 06:05 |  #15
SkipD wrote in post #8746525 (external link)
You can easily test any spirit level that you're trying to use with your camera. Suspend a plumb bob (or a home-made equivalent) so that the line (string) is in your test scene.
Works great for one dimension but the camera needs to be level in 2 for architecture.
Good to see the 7D has both catered for electronically - getting anything really accurate is a right royal pain. I have 3 bubble levels and all 3 are different ; hotshoe on the 5D is a bit out but the 5DII is reasonable. My current method is to use a Digi-pas electronic spirit level and work around the slight differences in hot-shoe setup from memory. This gets me accurate to 1 degree or so - good enough for most shots.
I guess the only viable solution is indeed the in-camera level - replacement bodies better have them :)
Michael Gove
http://photosignals.sm​ugmug.com (external link)
Google+ Profile (external link)
4,824 views & 0 likes for this thread, 22 members have posted to it.
2716 guests, 154 members online
