ken2000ac wrote in post #8752862
I'm relatively new to filters. "Relatively" because I have been using a Hoya Circular Polarizer and a Hoya NDx8 Neutral Density for awhile now. Both are 77mm screw-on types. Unfortunately, the ND filter I have been using is only worth 3-stops. It's been great, but I am in search of something much stronger.
Seeking: ND and Grad ND; 77mm screw-on. The thinner the better.
What do you fine gentlemen recommend?
As others have said, that for ND Grads you are much better off with a 4"x6" filter due to the ability to move it up and down to custom tailor the effect given where you want the horizon line to fall in your shot.
Furthermore, I recommend the 4"x6" filters due to versatility. If/when you add additional lenses to your bag which you will want to use the ND's and ND Grad's with, you will not need to replace these, simply purchase additional mounting rings. (In my bag I have rings from 49mm - 82mm).
Also, given that you wish to use it on a 77mm lens (I also use mine on an 82mm lens), buying for such sizes gets quite costly in screw-mount.
I recommend the Cokin Z-Pro system for such sizes. The benefit of Z-Pro is the ability to stack vs. being limited to only one filter in the wide-holder for the P-System (which I've owned since 1991). Also, getting the Z-Pro ND Grad Kit will get yourself a 2-stop, 4-stop, and 8-stop pack for about $160. I buy all my filters from here.
By comparison the Singh-Ray Vari-ND (which is VERY good, but not graduated of course) costs almost $400 for the thin-mount version (which in truth isn't THAT thin, but its thinner than their standard mount which costs $340). And the Singh-Rays are only available as 77mm and 82mm's so for any other lens you will need a step-up ring. You can get the Singh-Ray's here.
Bottom line, if you get the Cokin, you won't regret it... they are great. Plus you can stack other filters into the mix for added effect. Such as star filters and soft filters.
