Thread started 03 Oct 2009 (Saturday) 16:25
HELP! New PW MiniTT1/FlexTT5 and Elinchrom BX400's
BTBeilke
Oct 03, 2009 16:25 |  #1
I must be missing something simple, but I can't get the MiniTT1/FlexTT5 combo to trigger my BX400's. Is there some critical setting that I may be missing?
I can press the Test button on the FlexTT5 connected to the strobe and it fires as expected. However, when I press the Test button on the MiniTT1, I can see a red light illuminate on the FlexTT5 showing that it is receiving a signal, but it doesn't trigger the strobe.
FYI, I've tried using both a standard channel and a ControlTL channel but neither seems to work. Any help would be greatly appreciated.
Blane
alphonsis
Oct 04, 2009 03:15 |  #2
have you tested the combination with another flash/strobe to confirm the triggers work?
My flickr (external link)
Rebel XTi, BG-E3, 18-55 kit, 50 1.8, 70-200mm f/2.8 L IS, 28-135 IS, Tammy 17-50 2.8, 580EX II, LP120, 7MDH, 46" Softlighter II
BTBeilke
Oct 05, 2009 11:25 |  #3
alphonsis wrote in post #8756911 (external link)
They seem to work fine with my SpeedLite flashes. And, as I said, the "Test" button on the FlexTT5 will fire the strobe so I know that the cord connecting them is OK. And, when I press the Test button on the MiniTT1, the indicator light on the FlexTT5 comes on showing that it is receiving the signal from the Mini. That is why I feel like I don't have something configured correctly in the software setup. If someone is using these with Elinchrom strobes and good spell out how it is configured in the software, I'd appreciate it.
Blane
743 views & 0 likes for this thread
Latest registered member is mentalcare
2067 guests, 309 members online
