Thread started 03 Oct 2009 (Saturday) 17:02
Help with setup
markimage
Oct 03, 2009 17:02 |  #1
These two images shot with 30D+100mm macro f2.8. Setup was P mode into night sky using 580EXII Speedlite + 430EX coming from behind and below the spider
Result is poor to say the least. What settings should I have used?
This shot was P Mode using 530EX only - 2stops underexposed
http://www.markwebb.sm​ugmug.com/ (external link)
Canon 650D, Canon 1D Mk III, Sigma 10-20mm f4, Canon EF-S 17-55 IS f2.8, Canon EF24-105 f4, Canon EF100 f2.8 Macro, Canon EF70-200 L IS f2.8, Canon EF100-400 L IS,
LordV
Oct 04, 2009 01:06 |  #2
Tricky doing a spider in web with no background close by. I never use P mode- either use M mode for full flash shots or use Tv or Av modes for fill flash.
For M mode I would have set ISO100/200, F11, 1/200th and around -.66 FEC on the flash.
For Fill flash - Tv or Av and adjust ISo to give around F5.6- F8 at 1/200th. EC set at -.66 and flash at -1 FEC
This assume the flash is in ETTL mode
Brian v.
Macro Hints and tips
markimage
Oct 04, 2009 02:06 |  #3
Many thanks Brian, I'll give that a try.
LordV
Oct 04, 2009 02:21 |  #4
markimage wrote in post #8756735 (external link)
Should add I shoot RAW so do have a bit of latitude with exposure.
Brian v.
tintinb
Joined Sep 2009
Oct 04, 2009 02:59 |  #5
LordV wrote in post #8756514 (external link)
Brian v.
Wish I had this info to use my flash effectively for the following shot - without disturbing her.
Instead I captured her in ambient light (40W over the range lamp in the kitchen). She was hanging from a single string from under the hood over the range and was exceptionally quite (fortunately). I decided not to startle her - bring my 2220 explorer with all the rig pre-assembled. Inching forward very slowly to get enough of her in frame - and then a long exposure(74sec) on Av.
You can see the larger photo in this link
http://www.pbase.com/t​intinb/image/55875813&​exif=Y (external link)
tintinb
Joined Sep 2009
Oct 04, 2009 03:02 as a reply to  @ tintinb's post |  #6
It moved one of its leg (left lower corner of the image/spider) very slightly once when I accidently breathed out during the exposure. You can see the same leg in two different but close positions.
1,002 views & 0 likes for this thread, 3 members have posted to it.
Help with setup
932 guests, 183 members online
