Thread started 03 Oct 2009 (Saturday) 18:13
ST-E2 and 2nd Curtain Question
TheFloridaShooter
Oct 03, 2009 18:13 |  #1
I have been trying to shoot 2nd curtain off flash shots using a ST-E2 and either a 580EX II or a 430EX II without any luck. Is this even possible? I've tried setting this up on the XSi or the 50D. I can program 2nd curtain flash with the flash mounted on the camera but when I take it off and go through the ST-E2 I nolonger have the 2nd Curtain option.
What am I doing wrong?
1Dx MKII | 1Dx | 5D MKIV | 5D MKIII | 5Ds r | 5Ds | 7D MKII | 7D | G16 | G3x | EOS M & M3 | 800 f5.6 | 600 f4 | 400 f2.8 | 300 f2.8 | 200-400 f4 | 100-400 f4.5 - 5.6 II x 2 | 70-200 f2.8 | 14 f2.8 II | 50 f1.2 | 50 1.4 | 85 f1.2 | 135 f2 | 24-70 f2.8 II | 11-24 f4 | 35 f1.4 II | Pentax 645Z | SMC Pentax-DA 645 25mm F4 AL | SMC Pentax-D FA 645 55mm F2.8 AL | Pentax 90mm f/2.8 D FA 645 Macro ED AW SR | SMC Pentax-D FA 645 200mm f/4 IF | SMC Pentax-D FA 645 300mm f/4 ED IF | SMC FA 645 400mm f/5.6 ED IF Lens
k_strecker
Oct 03, 2009 18:14 |  #2
you're shooting canon :(
duno why canon has set it up this way . . . but they have.
TheFloridaShooter
Oct 03, 2009 19:02 |  #3
I found the answer........... That sucks
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Oct 03, 2009 19:50 |  #4
Canon prevent second-curtain except when full 6-channel communication between flash and computer is available, such as on-camera or full-service off-camera cable.
Remember that the main flash head emits the command to the slave to fire - while the shutter is open. That is true for front or rear curtain, but not HSS.
The light of the command flash illuminates the captured image, especially in low light. So with second curtain you would get blur - low flash - full flash on a moving object!
I understand that Nikon has a different arrangement, and people complain about the spurious illumination. Of course!
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
monty28428
Oct 03, 2009 20:14 |  #5
CliveyBoy wrote in post #8755190 (external link)
I like your explanation but I thought the ST-E2 used infra-red to communicate to the slaves -- thus there would be no light from the command flash (the ST-E2) to ruin the intended capture. If this is true your explanation does not make sense.
PacAce
Joined Feb 2003
Oct 03, 2009 20:54 |  #6
Not sure I follow your explanation of why 2nd curtain sync is not supported in wireless ETTL mode. How is the command flash firing just before the 2nd curtain sync flash goes off different from the command flash going off when 1st curtain sync is used in a low lighting environment?
...Leo
CliveyBoy
Joined Nov 2005
Oct 04, 2009 01:44 |  #7
monty28428 wrote in post #8755293 (external link)
You're right. Retires back to sick bed...
Toneski
Oct 04, 2009 03:03 |  #8
TheMissouriShooter wrote in post #8755032 (external link)
Hi Jon,
Do you have a link for the answer?
Thanks,
Tone.
I shoot Canon's me....
1ds3 - 21ZE - 35ZE - 100 Macro - 70-200 4L - 580's
Hellbelly
Oct 04, 2009 07:09 |  #9
The answer is......
It doesn't work :(
2nd Curtain only works with the flash on camera (or connected with an off-camera cable).
Flickr (external link) Facebook (external link) Twitter (external link) Blog (external link)
PacAce
Joined Feb 2003
Oct 04, 2009 08:49 |  #10
Hellbelly wrote in post #8757284 (external link)
The answer is......
It doesn't work :(
And to further clarify, 2nd curtain sync doesn't work when the flash is in wireless mode, either, even if it's sitting on the camera or connected to the camera via the off-shoe cord.
...Leo
apersson850
Oct 04, 2009 12:56 as a reply to  @ PacAce's post |  #11
Canon's slaves can normally not be used as ordinary slaves, i.e. triggering from just any flash. They have to be triggered by Canon's wireless system.
This works with a set of pre-flashes, to control metering and command the power setting. After the pre-flashes have fired, the slave is actually in "stupid slave mode" for a brief moment. This is to wait for the flash that fires from the camera when the picture is actually taken.
With 1st curtain flash, this trigger flash comes pretty soon after the command flashes. But if 2nd curtain sycn would be possible, the trigger flash could come any time after the command flash (at least 30 seconds, and worse if using Bulb), so they wouldn't know when to stop looking for it.
Nikon may have a different solution. I only know how Canon works.
Anders
Curtis ­ N
Master Flasher
Oct 04, 2009 14:21 |  #12
Here's how to make this work.
1) Put your 430EX on the hotshoe, in manual mode, set for 2nd curtain. If you don't want it to contribute to the image then set it to low power, zoom it to 105mm and aim it at your slave.
2) Get an optical slave like this  (external link)for your 580EX II. Use that as your slave.
tim
Light Bringer
Oct 05, 2009 04:49 |  #13
In five years of photography i've never needed 2nd curtain sync. I always wonder what people use it for, and if they actually needed it or not.
GerBee
Oct 05, 2009 07:03 |  #14
tim wrote in post #8762629 (external link)
It's main use in getting the flash trail effect with moving objects at night or similar type of situations.
If one is shooting a long shutter of a passing car, say 1/4 sec, then the flash illuminates first and make the car look as if it is going backwards.
If one uses second curtain sync the flash is at the end of the exposure and the flash trail is going the right way making the car look like it is going forward.
District_History_Fan
Oct 05, 2009 08:26 as a reply to  @ GerBee's post |  #15
Canon really needs to find a way to allow wireless 2nd curtain sync... That would be my default setting.
www.ericmcferrin.smugm​ug.com (external link)
1,779 views & 0 likes for this thread
Latest registered member is KathKirk33
981 guests, 310 members online
