Thread started 04 Oct 2009 (Sunday) 14:01
Night Football Noise Help
rangerfan12
1 post
Oct 04, 2009 14:01 |  #1
I am struggling with my photos of high school football night games. I have a Canon 50D with a 70-200 2.8L IS Lens and my photos look like a kit lens. The noise is horrible. Here a couple samples with varying settings, I just cant seen to get a well lit clear image that is not blurry. I have seen pictures of people that taking images next to me and they are perfect.
The settings for this picture were:
ISO 1000
148 MM
f/2.8
1/400 sec
why the noise?
Sledhed
Joined Jun 2005
Oct 04, 2009 14:13 |  #2
The photo is WAY under exposed. Raise your ISO or use a flash. If you under expose a picture and lighten it in Photoshop you will bring out more noise.
Chris
Gear List | Website (external link) | Sports Sample Pictures (external link) | Four Seam Images (external link)
If you’re good at something, never do it for free. - The Joker
n1as
Oct 04, 2009 16:56 |  #3
As you underexpose, noise goes WAY up. Your image is terribly underexposed. You should be shooting at ISO 3200.
If you're under artificial lights, shoot in M mode. Crank your ISO and shoot with the lens wide open. Adjust SS until the histogram of your shots is pushed to the right. Don't trust your light meter.
- Keith
http://darwinphoto.zen​folio.com (external link)
XTi ­ Guy
Oct 04, 2009 18:23 as a reply to  @ n1as's post |  #4
+1 with above advice.
Rockfreak300
Oct 04, 2009 18:52 |  #5
The 50D is notorious for HORRIBLE noise.
I have a 50D myself and it's definitely not my Mark III when it comes to noise that's for sure.
Other than that, I highly agree with what the others have said above. :)
900spg
Oct 04, 2009 18:56 |  #6
Yes, change to iso 3200 for these conditions as the underexposure is causing the bad noise.
Canon 5D MkIII | 7D | 40D | 350D
580EX II - 430EX II - BG-E3
50mm 1.8 II | 85mm 1:1.8 | 100mm 1:2.8L | Tokina 12-24 f4 | 24-70mm 2.8L | 70-200mm 2.8L | 100-400 4.5-5.6L | Kenko Extension Tubes and 1.4x Teleconverter
www.jpsphotos.net (external link) flickr (external link) TrekLens (external link)
Playonpics.com
Oct 04, 2009 19:16 |  #7
So a higher iso such as 3200 would make less noise?!
i think 1000 is low, but i wouldn't go much more then 1600 on a 50D or 40D. Noise would be terrible... without using software to fix it...
Canon 1D MarkIII | Canon 7D | 70-200mm F/2.8L | 24-70mm F/2.8L| 300mm F/2.8L IS | 50mm f/1.8 | 85mm f/1.8 | 15mm f/2.8 Fisheye | 580EXII Flash | Computrekker | ThinkTank roller and beltsystem | Elinchrom (2) Dlites 4IT Canon Platinum CPS Member
www.playonpics.com (external link)
Dan-o
Oct 04, 2009 19:18 |  #8
then put your gear away and watch the game. You need to shoot the proper iso for the situation. Trying to underexpose instead of going to a higher iso isn't going to help.
Danny.
DMunsonPhoto (external link)
Cycling Illustrated (external link)
FaceBook Page (external link)
canonnoob
Oct 04, 2009 19:19 |  #9
Ranger,
From the looks of your photo, the others are correct. You photos are quite under exposed. I would suggest boosting your ISO. Yes the images will be "noisier" than the one you have posted now, but when you boost the exposure in post. that image will almost be ruined. You have some great gear, and I will look forward to seeing you meet your potential when getting used to it.
David W.
Playonpics.com
Oct 04, 2009 19:23 |  #10
Dan-o wrote in post #8760290 (external link)
Dan, your hardly talking about the same thing. Shooting with your MarkIII, and then myself shooting with a 40D at 1600 your hardly seeing the same type of image.
Dan-o
Oct 04, 2009 19:25 |  #11
It isn't gear dependent. My MIIn is also bad at 3200 but I'm not going to underexpose at 1600 because it will be even worst.
Danny.
Sledhed
Joined Jun 2005
Oct 04, 2009 19:41 |  #12
Danny is correct, one of the best things you can do to help control noise is to expose the image properly. If that means using a higher ISO, then you use a higher ISO.
Chris
900spg
Oct 04, 2009 20:35 |  #13
A properly exposed image at iso 3200 is not as bad as many think and I believe less noise than these show. I shoot almost all of my hockey at iso 3200 and find the noise to be acceptable. Some 40D iso 3200 shots in this thread.
liam5100
Oct 04, 2009 21:56 |  #14
Dan-o wrote in post #8760336 (external link)
Exactly Dan is right.. IF you underexpose an ISO 400 image drastically and then push it back up in post you'll have much more noise and less IQ than your 1600 on your 50D.
Bill -
Equipment : Quaker Oatmeal box with a little tiny hole in it... and a 400 2.8
Mike ­ R
Oct 04, 2009 22:07 |  #15
Welcome to POTN. The majority of us use flash, each with our own technique.
There are many threads that will help you with night football.
Here's a link to one of them:
https://photography-on-the.net/forum/showthre​ad.php?t=735799
Mike R
www.mikerubinphoto.com (external link)
1,660 views & 0 likes for this thread, 12 members have posted to it.
2848 guests, 137 members online
