PS 5 LE came with my G2. How does it compare with PaintShop Pro 7 and the current version of Phoshop Elements?
geecee Member 131 posts Joined Jan 2003 Location: Melbourne, Australia More info | Feb 04, 2003 04:00 | #1 PS 5 LE came with my G2. How does it compare with PaintShop Pro 7 and the current version of Phoshop Elements? Graham
elgenper Hatchling 9 posts Joined Sep 2002 More info | Feb 04, 2003 13:51 | #2 PSLE is quite good; stay with it if you got it free! One "weakness" is, it has only one undo step. Elements would give you several steps, also adjustment layers, but you would lose Curves, which is very useful. A weakness with LE that may or may not be important for you is that it doesn´t support color profiles; Elements does.
john_houghton Member 175 posts Joined Feb 2002 More info | Feb 05, 2003 02:10 | #3 PS LE has some advantages over PS Elements, and vice versa. LE has curves, 16 bit image mode and fully fledged layer masks, all of which are extremely useful in image editing but which you don't have in Elements. You might as well use LE since you already have it. It will take a little while to learn how to use it (don't overlook the user guide on the CD).
Feb 05, 2003 23:36 | #4 Thanks all. That is very useful. I have tried several early versions of PSP (off mag covers) and was on the verge of buying v7. Then PSLE landed in my lap so to speak. Graham
john_houghton Member 175 posts Joined Feb 2002 More info | Feb 06, 2003 02:08 | #5 geecee wrote:One thing I would like to do but can't with PSLE is to correct converging vericals. There's a free Photoshop plugin available to correct perspective. It's part of Panorama Tools from http://www.all-in-one.ee/~dersch/
| Latest registered member is IoDaLi Photography 1591 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
