Once your 7D does come in. Please, please do yourself a favor and do Micro adjust all your fast lenses. For all I know, half the problems with AF are a result of not understanding the need to MAF. Unless perfectly calibrated (on the one hand it probably makes everything expensive and on the other: unlikely, knowing Canon's QA folks).
I was like: "damn sigma". Brand new Sigma 30/1.4 with brand new 7D and all I was getting was softness (in Spot AF mode). I know how good the Sigma/50 was on my 5D2 and expected the same from the 30. I didn't want to bother with the lens align kit as it was useless in the past at the recommended 50X distance for the Sigma 50 and I wanted my main lenses dialed in before I head out to Laguna Seca tomorrow
Long story short. The Sigma 30/1.4 needed +12, my brand new 17-55/2.8 needed +10 and the 100-400 needed +9. I was shooting near and far objects and have probably taken some 200 shots just for MAF. If you spend enough time, the MAF can be made consistent for both ends of the zoom. Didn't have grass around for DOF indication but used other things.
MAF is a must for happiness. Especially if you expect happiness to arrive packaged with the 7D (And I do for the money I paid for it). Given how the lenses and cameras are calibrated to different references and not to each other. It is always a degree of how much MAF and not whether MAF is needed or not. The odds are quite low that your camera and lenses are perfectly matched.
MAF itself seems to be a vague thing if done with the wrong tools. For my 17-55, I measured the distance to an ojbect (cycle seat's back), looked up the DOF charts and started changing the MAF numbers till the expected rear DOF was achieved (entire seat to be in focus). Then confirmed DOF (rear/front) for a closer object by placing markers before and after the focal plane at the DOF limits.
The 30/1.4 is simpler to MAF as the purple/green loca helps to visually indicate DOF boundaries. Simply place a small item on a white paper (with a dark background). Basically any heavy contrast bg, figure out the DOF for the distance and simply adjust MAF till the purple/green spacing around the focal plane is correct.
Looking at the numbers, I think all my lenses (including the product of a much maligned Sigma QA) are very close to perfect calibration: the 7D however, seems to be consistently front focusing. All within tolerance I should think (as it falls in the MAF limits of +-20) but someone who didn't bother with MAF will end up feeling disappointed and curse the camera instead.
I would like my data point, however statistically insignificant, to help separate the actual AF performance for this body from issues caused by uncalibrated AF. I have high hopes that canon made the AF algorithms robust enough.
The 7D is real nice to hold. Much better in my hands than the 5D2. I am not used to (and hence dislike) the tightness of the rear-dial (5D was significantly easier to turn).
Canon preusmably increased the effort required to push bottons to prevent unintended button presses. However, there is some lack of consistancy. The difference in pressure required for most of the buttons is higher but the shutter button needs very low effort. This confuses the operation as I need to be firm everywhere except at the shutter.
The camera package as a whole is here to stay though! No buyers remorse whatsoever as most things work as expected and promised. I was happy with the ISO performance of my 20D, the 7D is decidedly superior. Low light AF is superb compared to the 5D2. No hunting with any of my lenses. Mirror slap is less (natural as the mirror is smaller and probably also much better damped to allow 8fps) and the camera therefore requires a lighter grip than the 5D did. The grip allows me to twist the camera down more easily (I push up on the bottom of the lens, twist the camera down and pull the camera into my face to stabilize it).
The only funny thing was the way the EP1 rewired my brain. I keep pressing on the bottom of the rear dial to move the menu items down . The EP1's dial rotates and clicks. My wirst realizes now how heavy the 7D+100-400 is: the EP1 has wimped me out.
happy shooting all! Remember "MAF could create big DIFF for DIF" (sorry.. couldn't help it)
