Thread started 09 Oct 2009 (Friday) 00:46
Lighting Help
Tumeg
Oct 09, 2009 00:46 |  #1
So, I'm working on getting a price to a client for a Girl Scout, father daughter dance shoot.
They want a photo of each couple (240 couples). It will be dark (6-9pm) and indoors, so I will pretty much need to rent a mini-studio.
So that's why I'm here! I need some BASIC lighting help!
I figure all I really need is 2 strobes\lights, umbrellas or soft-boxes, stands, and pocket-wizards (Or an ST-E2 if I just go the 580EX II route)
I went on lensrentals.com to try and get some stuff together, and some pricing, and decided that I have no idea what I really need, or how to get it all to work!
Help would be greatly appreciated. Also, before you suggest something, please check lensrentals.com to be sure they have it :)
| Canon 5D Mk II | Canon 17-40MM F/4L | Canon 50MM F/1.4 | Canon 85MM F/1.8 | Canon 580EX II |
Roger ­ Cicala
Joined Jan 2005
Oct 09, 2009 06:56 |  #2
There's a million ways to do it right, but the simplest in my mind is a couple of shoe mount flashes mounted to lightstands
https://www.lensrental​s.com …hoe-to-lightstand-adapter (external link)
or Gorillapods
https://www.lensrental​s.com/rent/gorillapod-large (external link)
in softboxes
https://www.lensrental​s.com …hoe-flash-softbox-15-x-15 (external link)
triggered by your on-camera flash or an ST-E2
Not too heavy to carry around, easy to set up, no radio triggers and cables to malfunction.
(and I did check to make sure Lensrentals had them :-)
My gear is www.lensrentals.com (external link)
SnlpeR
Oct 09, 2009 07:16 as a reply to  @ Roger Cicala's post |  #3
i suggest you do NOT go with the battery operated route
240 couples is a lot
i would prolly keep it simple
if i were to do it...id just use 2 alienbees with shoot thru umbrellas
one left and one right
one side 45 degrees from the couple and the other as fill light more than 45 degrees on the opposite side...almost to the side of them
Tumeg
Oct 09, 2009 14:24 |  #4
How about this little setup?
http://www.lensrentals​.com …two-head-studio-flash-kit (external link)
With pocket-wizards... (Will I need 3 pocket-wizards? 1 to send from the camera, and then 1 for each strobe?)
Roger ­ Cicala
Joined Jan 2005
Oct 09, 2009 16:53 |  #5
Tumeg wrote in post #8791837 (external link)
That's nice too. You can use PWs: one on the hotshoe to send, and one receiving on each strobe. Or you can trigger the second strobe by the flash from the first and just use one receiving PW.
Tumeg
Oct 09, 2009 18:13 |  #6
Roger Cicala wrote in post #8792577 (external link)
Alright, and 1 more question for that setup.
Do both of those strobes connect to that one battery(thing)?
If so, can I plug the battery (I'm pretty sure that's what it is) into an outlet? Or will I just need to find\rent a second one?
I plan on firing these strobes around 300 times, for the one shoot... So I may need some extra power :confused:
eviljunglenoodle
Oct 10, 2009 01:50 |  #7
That is just a power pack, it would plug into an outlet and the lights plug into the power pack which basically is just your light power control.
1,141 views & 0 likes for this thread, 4 members have posted to it.
Lighting Help
1495 guests, 125 members online
