Thread started 10 Oct 2009 (Saturday) 12:26
1D Mark IIn Help with Error message
wfcs1962
Oct 10, 2009 12:26 |  #1
I was shooting football last night and the shutter would not fire and "err 99" came up on the top display. I switched the camera off and on several times and kept trying before it finaly started working again.
Any Ideas.
I am thinking about sending it in before Basketball season starts for me and using my back up for now.
Thanks for any input
Frank
Frank
Canon 1D Mark IIn 85 1:8 70-200 2:8L 300mm 2:8L Lots of gadgets
spalmer
Oct 10, 2009 12:31 |  #2
Sounds like your shutter is on its way out. I had a similar problem off and on a month before my shutter finally broke.
Steve
1dMIIN & 40D : 400mm 2.8L, 70-200 2.8L, 24-70 2.8L, 28 1.8, 50 1.8
tfd888
Oct 10, 2009 15:32 |  #3
err 99 is an error code that all Canon EOS digital cameras throw when the camera does not really know what is wrong and could really be anything and does not necessarily mean that the shutter is going bad.
Try gently cleaning your lens and body contacts with an eraser head and see if the issue persists.
If it does, a trip to Canon may be the best and only thing if you need to depend on that body for shooting.
Alexander R.O.
1D-Mark III ~1D-Mark II ~ 60D ~ 20D (Gripped)
(70-200mm L 2.8 IS) ~ (17-40mm L 4.0) (Sigma 24-70mm 2.8 EX DG Macro RIP) ~ (50mm 1.8 MKII) ~ (Alpex 35mm f/2.8 M42 mount) ~ (430EX II) ~ (Yongnuo YN-560 III)
My Website (external link) - My Blog (external link)
- My Flickr (external link)
S.Horton
Oct 10, 2009 15:36 |  #4
spalmer wrote in post #8796325 (external link)
+1 that's how mine started to go.
Sam - TF Says Ishmael
:cool:
JWright
Joined Dec 2004
Oct 10, 2009 18:07 as a reply to  @ S.Horton's post |  #5
One Err99 is not a sign the camera is failing... My 20D gave an Err99 a couple of years ago and it's still working fine and has never done it again...
Way too much has been read into what is really a catch-all error code...
John
Bill ­ Roberts
revolting peasant
Oct 10, 2009 18:25 |  #6
JWright wrote in post #8797595 (external link)
I have to agree with this. Err99 is a bit of a "catch all" code. I too had this some years ago with a 20D fitted with a grip and removing and re-fitting this seemed to cure it. Obviously that's not the case here with a 1DIIN but it really does seem to be a bit of a "generic" error code. It certainly can't harm anything to clean the lens contacts with an eraser though as that seems to be the most common fault I've seen reported. It may be a sign of something more serious but I wouldn't worry too much just yet.
BiLL
pwm2
"Sorry for being a noob"
Oct 10, 2009 18:25 |  #7
I get Error 99 if trying to use old Sigma lenses. Happens on several bodies. There really are no easy answer to what the case of an Err99 is.
wfcs1962
Oct 11, 2009 10:36 |  #8
Thanks I will try cleaning the sensors but last night it threw the code and I could not get to operate again. After I clean them and check it I will go from there and see.
Thanks for the input.
Frank
Bill ­ Roberts
revolting peasant
Oct 11, 2009 11:12 |  #9
If it locks up totally Frank, try removing both the main battery and also the backup battery (is this a CR232?) and leave it for a couple of minutes for any charge to leak away, then re-install them. Do be aware that this will lose any custom settings and you'll also have to re-enter time and date settings too. It's not a cure but sometimes kicks things back to normal. Of course if it's locked up anyway you don't have a lot to lose :(
Hope it gets sorted soon
cheers
Bill
BiLL
pwm2
Oct 11, 2009 11:21 |  #10
It isn't the sensor you have to consider cleaning. It is the gold connectors for the lens. But that is only if the error is because of communication problems with the lens. Hhave you tried different lenses, by the way?
wfcs1962
Oct 12, 2009 21:16 as a reply to  @ pwm2's post |  #11
I cleaned the pins on the camera and the gold contacts on my 300 2:8 and it seems fine for now. I tried it before I went to work and when I got home I fired off a few frames. Before I cleaned anything I did try several lenses with no luck so I hope this keeps me going.
Thanks for all the help
Frank
Frank
3,157 views & 0 likes for this thread, 7 members have posted to it.
1121 guests, 169 members online
