Thread started 10 Oct 2009 (Saturday) 22:36
Which to buy, 70-200F4 IS &135L or 70-200F2.8 IS
jkokbaker
Oct 10, 2009 22:36 |  #1
Which would you buy, only a couple hundred dollars more for the combo. I am thinking the combo, but is the 2.8 too nice to have to pass on?
5D IV, Rokinon 14mm, Zeiss 21mm, Rokinon 24mm 1.4, Canon 24-105L, Speedlight 430EX II
slowcivic07
Oct 10, 2009 22:54 |  #2
I have the 70-200 f4 IS and it's great. I think the f2.8 is too big to carry around and it's not much faster.
40D, EF 70-200 f/4 IS, 35 f/1.4, EF-S 60 f/2.8, Speedlite 580 EX II
Dorman
Joined Feb 2006
Oct 10, 2009 22:56 |  #3
Check out the search, there's a ton of similar threads in the archives and a few active ones on the first page of this sub forum currently.
Rey.dos
Oct 10, 2009 22:58 |  #4
2.8....
http://www.flickr.com/​photos/reyjosue/collec​tions/ (external link)
AKHOO
Oct 10, 2009 22:58 |  #5
I have the 70-200 f/4 L IS and 135L combo. Love it. If I'm out shooting candids or know that I'll be taking portraits only, I take the 135L. If I'm out at the zoo, etc. they both come along.
EOS 7D | 35L | 85L II | 135L | 430EX II | Flickr (external link)
Marloon
Oct 10, 2009 23:02 |  #6
70-200 f4 is, 135l. I'm thinking of adding these to my collection.
I am thinking of the following a my lens line up. 17-40, 24-105, 70-200 f4 is, and 135l.
I'm MARLON
Former Canon Platinum CPS member
5DII • 24L • 35L • 50L • 85L • 135L • 200LIS
Wordpress Blog (external link)Youtube Channel (external link)Twitter (external link)Gear List (external link)
jkokbaker
Oct 10, 2009 23:03 |  #7
Dorman wrote in post #8798778 (external link)
I did and did not find anything about all 3 of these lenses, thanks though.
Dorman
Joined Feb 2006
Oct 10, 2009 23:08 |  #8
jkokbaker wrote in post #8798809 (external link)
Here are a couple threads you might find of interest, the first is one that was posted by me. I own the 70-200 F/2.8 IS and have been considering the merits of moving to the F/4 IS + 135L myself.
https://photography-on-the.net/forum/showthre​ad.php?t=749727
Here is one where a fella went from the 2.8 IS and the F/4 IS + 200 F/2.8 prime. Close to your question...
https://photography-on-the.net/forum/showthre​ad.php?t=763849
Here's one pretty much directly related to your query...
https://photography-on-the.net …4369&highlight=​70-200+135
Hope these threads will help as I'm still undecided. Good luck with your decision!
Jeff81
Oct 10, 2009 23:15 |  #9
I've had all three lenses and preferred the 70-200 f/4 and 135L combo. Both options are great though. If you're leaning toward the combo go for it. I don't think you'll be disappointed.
R6/6D | Canon 24-105L f/4 IS, Samyang 24 f/1.4, Sigma 50 f/1.4 Art, Canon 85 f/1.8, Canon RF 70-200 L f/2.8 IS
Feedback
Marloon
Oct 10, 2009 23:29 |  #10
The only problem I have related to this combo is the fact that yOud need different sized filters - If you use them such as nd, and circular polarizers. The 70-200 f4 is uses a 67 filter if I'm not mistaken. And the 135 uses 72. You'll be hooked to the prime lens trinity after the 135. You'll question the quality and performance of the other l primes and soon, will attain them for their amazing performance. Once you are poor and have the 24,35,50,85,135,200 set, you can then look at the bright side. At least the filter size is 72mm.
I'm MARLON
zoom_zoom
Oct 10, 2009 23:51 |  #11
I've got the f4 non-is at the moment and am leaning towards purchasing the f2.8IS version... still pondering over what to do at the moment.
RPCrowe
Joined Nov 2005
Oct 11, 2009 00:16 as a reply to  @ zoom_zoom's post |  #12
I carry two 1.6x cameras (30D and 40D) with the 17-55mm f/2.8 IS and the 70-200mm f/4L IS lenses. This is an extremely versatile combination for general and travel photography.
The 70-200mm f/4L IS is a LOT LIGHTER IN WEIGHT than the f/2.8L models. I can carry the f/4L IS lens AND a second camera right at about the weight of the 70-200mm f/2.8 L (series) lens alone. The f/4L IS lens is also a lot smaller and easier to carry.
Additionally, I was able to buy the 70-200mm f/4L IS AND a refurbished 40D for just about the same price as the f/2.8L alone.
I can shoot at 1/60 second @ f/4 using 200mm and expect close to 100% sharp shots (the ones that are not sharp are due to operator error).
I can shoot at 1/30 second @ f/4 using 200mm and expect a very satisfying percentage of sharp shots.
The above ability combined with the good ISO performance of the 40D camera frees me from using the 70-200mm f/4L IS lens as bright day only lens (as I was forced to do using my f/4L non-IS model).
I carry the 30D and 40D with 17-55mm f/2.8 IS and 70-200mm f/4L IS lenses just about everywhere on an OPTECH Dual harness which makes using them very fast and easy and which distributes the weight across my shoulders rather than hanging from my neck. The harness image is not of me but, it is the harness that I use. I just wish I were as slim as the guy in the image.
By the way, the f/4L IS lens can produce a very narrow DOF and this lens has exceptionally smooth Bokeh as indicated by this portrait of my Goldendoodle.
Regarding the use of different size filters... Since I shoot with two cameras, I would use two filters even if the lenses accepted the same size filter. Having to switch filters would negate the advantage of shooting with two cameras. The 67mm size for the 70-200mm lens is a lot less expensive than the 77mm I use for the 17-55mm lens.
agv8or
Gallery: 10 photos
Oct 11, 2009 00:18 |  #13
I have both the 70-200 f4 IS and the 70-200 f2.8 IS but have thought about selling the f2.8 and buying a 135L. Since buying a 5DmII (which is very good in low light with very little noise as compared to my original 5D's) I rarely use the f2.8 and opt for the f4 for its small size and less weight. I have a very sentimental attachment to my 70-200 f2.8 IS lens though as it hung around my neck for about 5 years and now I have chronic neck and shoulder pains so selling it would be admitting defeat and I hate to give in. If I sold it I would still like to have a fast lens in that focal range just in case (you never know) so the 85L or 135L are logical choices with the 135L being the cheaper choice plus I already have an 85 f1.8 that rarely gets used. If I were starting from scratch today knowing what I know now with a camera like a 5DmII I would probably lean towards the combo just because I would have all the bases covered minus the weight and all the side effects that go with it down the road.
Rand
Gear
bohdank
Oct 11, 2009 00:47 |  #14
f4 IS and 135L, no question.... but that is me.
binlerne
Oct 11, 2009 01:08 |  #15
Depends on what you shoot, but I definitely loved both the F4 IS and 135L. I shot with a 2.8 IS a long time ago and all I remember from that thing is it is HEAVY. I did get some great shots out of it though.
My Website (external link)
2,294 views & 0 likes for this thread, 15 members have posted to it.
653 guests, 121 members online
