FORUMS Photography Talk by Genre Sports Talk
Thread started 11 Oct 2009 (Sunday) 18:40
Gymnastics awards pictures. Which lens?
felixapproach
Oct 11, 2009 18:40 |  #1
I was just wondering what all of you gym parents are using to shoot awards. I have tried my 50mm f1.8 and my kit lens, but not happy with either. Do you use flash or try to shoot with available light? I Shot this last night and was not very happy. It was a short notice thing and I was not at all prepared. I think it was iso3200 f4.0 1/100sec.
40d w/ grip, 75-300 f4-5.6, 85mm f1.8, 50mm f1.8, 18-55 is, Bowers SFD728c, 160ws Flashpoint strobe
canonnoob
Oct 11, 2009 18:43 |  #2
i shoot flash when doing trophy and medal presentation...
example- i know it isnt gymnastics but...
David W.
felixapproach
Oct 11, 2009 18:47 |  #3
Thanks Dave. I'm so used to no flash that I didn't even bring one.
wyofizz
Oct 11, 2009 19:46 as a reply to  @ felixapproach's post |  #4
Felix.
The issue with the above pic seems to be WB.
Dave - Fuzzy Hashing makes me itch.
russbecker
Gallery: 41 photos
Oct 11, 2009 19:59 |  #5
White balance is always the issue in gymnastics photos, you either need to find something white or wing it, unless its your home gym and you have already custom set the white balance.
As for the lens, it depends on where I'm at. 85mm f/1.8 at medium distance, one or two gymnasts, 135mm f/2 if further back; have used the 70-200 f/4 on a monopod. Group shot, 17-50 f/2.8. Typical exposure would be 1/160 at f/2 at ISO 1600; if I need more DOF then f/2.8 at ISO 3200.
7D2 | 80D | Fuji X-H1 | 100-400 f/4-5.6 IIL | 300 f/4 L | 70-200 f/2.8 IIL | 135 f/2 L | 85 f/1.8 | 100 f/2 | 60 f/2.8 macro | nifty-fifty | 10-22 f/3.5-4.5 | Tamron 150-600 | Tamron 17-50 f/2.8 | Sigma 30 f/1.4
Naturalist
Adrift on a lonely vast sea
Gallery: 93 photos
Oct 11, 2009 20:03 |  #6
Dave, can you describe what you used to light the group image?
Doug
My Gear List
http://www.douglasbrow​nsr.com (external link)
Entered: 2-16-84 Passed: 5-22-84 Raised: 6-19-84
canonnoob
Oct 11, 2009 20:05 |  #7
430 ex fired on camera(40d in this instance) with the 16-35 2.8 II at 25mm. F9 power on the flash was ..... 1/8th I think.. It was shot in manual. (the flash that is)
David W.
Naturalist
Gallery: 93 photos
Oct 11, 2009 20:20 |  #8
Thanks Dave.
Doug
My Gear List
canonnoob
Oct 11, 2009 20:32 |  #9
no problem doug
David W.
int2str
Oct 11, 2009 20:47 |  #10
I don't think the original is too bad. The white balance seems to be the biggest issue. I've played with the image a bit and attached the result.
The noise at ISO 3200 caused quite a bit of detail to be lost as well (faces). Given the shutter speed and aperture, I think you could have gone down to 1/60th possibly and ISO 1600 to get a cleaner image. I'd experiment a bit with that.
But yes, flash would probably be better. It may also help you under-expose the background a bit giving you less clutter back there...
kgoings
Oct 13, 2009 20:00 |  #11
I use my Tamron 28-75mm f2.8 and I use flash.
Dmab
Oct 14, 2009 12:04 |  #12
felixapproach wrote in post #8802707 (external link)
You could've used your onboard flash, yes?
Dan
eigga
Oct 14, 2009 12:54 |  #13
ANY lens that is wide enough will work for this... as mentioned this issue is lighting
-Matt
Website (external link)
Facebook (external link)
Instagram (external link)
pretzelhead
Jun 09, 2010 17:51 |  #14
eigga wrote in post #8821206 (external link)
Set up a couple umbrellas :lol:
I know what you mean. When it's in a gym I usually go no flash and use either 10-22mm (if I can get real close) or 50mm.
When it's inside a cafeteria (and I see you're from AZ so we may have even talked before--my daughter is at Tumbleweeds in Tucson), I bounce a flash and get a nice effect. I just picked up a 18-55 off of craigslist for $100 and I think that will be perfect for awards.
See you next season!
7D |EOS 20D | Nifty Fifty | Canon EFS 10-22MM f/3.5-4.5 | 70-200L 4.5 | EFS 70-300 | EFS 18-55 3.5-5.6 |
felixapproach
Jun 09, 2010 19:01 |  #15
Thanks pretzelhead,
I think we did talk at the Kim Bird meet. I'm off to the State Banquet in about an hour so I will get to try some more award shots. After that we are done until fall for my youngest and next year for my oldest.
Jay
5,178 views & 0 likes for this thread
Latest registered member is karozenix
943 guests, 304 members online
