Thread started 13 Oct 2009 (Tuesday) 18:07
Manual focus - do you do it with the focus points?
mrkgoo
Oct 13, 2009 18:07 |  #1
So I was playing around with manual focus, kind of brought about when the AF mechanism died on my 17-55.
Since the focus points still work in manual mode, it occurred to me that you don't turn these off, instead you use these to assist you. In particular, turning on ALL focus points, and then manual focusing until the point you want focussed beeps in confirmation.
Is this how it's supposed to be done? Or do manual focusers just turn every thing off and use the viewfinder?
It also occurs to me that the 19 point AF on the 7D is amazing for this.
stsva
Gallery: 45 photos
Oct 14, 2009 09:15 |  #2
There's no apparent downside to keeping the focus points active so you get confirmation of your manual focus accuracy, recognizing that the AF confirmation may not be completely accurate.
Some Canon stuff and a little bit of Yongnuo.
http://www.pbase.com/s​tsva/profile (external link)
Member of the GIYF
Club and
HAMSTTR
٩ Breeders Club https://photography-on-the.net …=744235&highlig​ht=hamsttr Join today!
Image Editing OK
cdifoto
Don't get pissy with me
Oct 14, 2009 09:21 |  #3
If my AF points can give me confirmation, I can use AF just as accurately and faster to boot.
apersson850
Oct 14, 2009 12:02 as a reply to  @ cdifoto's post |  #4
If I for some reason need to do critical manual focusing, I turn on live view, magnify the interesting part of the screen and focus there.
Anders
mrkgoo
Oct 16, 2009 14:16 |  #5
cdifoto wrote in post #8819861 (external link)
Well, sometimes you have a narrow DOF, and you want to take shots with different parts in focus, so you can turn the manual focus until one part confirms focus, take the shot, then turnout eh focus to another and take the shot, all confirmed with the points.
I was just asking if manual focusers actually leave the points on to guide them, especially with the 7D 19 points which cover a lot of the screen.
krb
Oct 16, 2009 14:18 |  #6
mrkgoo wrote in post #8835409 (external link)
How would that be any different than selecting the first AF point and using AF, take the shot, then select the second AF point and using AF again?
-- Ken
Gear list
mrkgoo
Oct 16, 2009 14:23 |  #7
krb wrote in post #8835422 (external link)
No different, but faster as you don't have to fumble with the AF-select button, then click the selector to the point you want, you simply refocus and click. 19 points means that's like clicking a few times :p. I guess it would be much simpler on the XXD/XXXD/5D to just hit af-select and then the one you want very quickly.
Now that I think about it, the focus points on those maybe less useful using manual focus as the points don't necessarily lie on the place you want in focus.
krb
Oct 16, 2009 14:39 |  #8
mrkgoo wrote in post #8835454 (external link)
You're doing it wrong. The 40D and 7D can both be configured to use the multi-controller (the little joystick thing) to directly select the AF point without fumbling around with any buttons.
-- Ken
Gear list
bobbyz
Oct 16, 2009 14:41 |  #9
Does 7D let you change number of active Af points like 1 series do?
5dmk3, 35L, 85L II, 300mm f2.8 IS I, 400mm f5.6
Fuji XT-1, 14mm f2.8, 23mm f1.4, 35mm f1.4, 56mm f1.2, 90mm f2, 50-140mm f2.8
Zephyrize
Oct 16, 2009 14:42 |  #10
my Xsi sometimes hunt badly, so I use MF+confirmation; it does work pretty well.
~Be the change you want to see in the world.
Flickriver. (external link)
krb
Oct 16, 2009 14:44 |  #11
bobbyz wrote in post #8835568 (external link)
You select modes. The options are: all 19 points active, zone, single AF with expansion, single point, and spot which is single point but with a smaller, more precise point.
-- Ken
Gear list
mrkgoo
Oct 16, 2009 14:50 |  #12
Sort of ... You have 5 different AF modes:
Full - all 19 points are active.
Single - choose one point.
Spot - choose one point that has a smaller area.
Single assisted - choose a point like single, but the surrounding 4 points are also active.
Zone - choose the centre 9, or the top/bottom/left/right 5 or so points to be active.
apersson850
Oct 16, 2009 16:58 as a reply to  @ mrkgoo's post |  #13
But when you are in manual select mode, you can't limit it to having to plow through less then 19 points, that's correct.
What you can do is open a backdoor, which allows you to go directly from the leftmost to the rightmost point, for example.
Anders
krb
Oct 16, 2009 17:06 |  #14
apersson850 wrote in post #8836334 (external link)
I'm not sure I understand what you mean by plowing through less than 19. If you mean when selecting a focus point, the longest distance is 6 points when going from one side to the other in landscape/horizontal orientation.
-- Ken
Gear list
apersson850
Oct 16, 2009 17:08 as a reply to  @ krb's post |  #15
Yes, I know. But out of the 19 points you can select in a 1D Mark III, you can exclude some to get it down to nine (I think) only. That you can't do on a 7D.
Anders
2,592 views & 0 likes for this thread
Latest registered member is majorsite2
930 guests, 239 members online
