the mm number is the "focal length" of a lens. shorter focal length = wider field of view for any given camera format. camera format is determined by the size of the imager (film, or digital sensor).
so yeah, for the 35mm format (35mm film, or the 1Ds series), all lens with the same focal length has the same FOV.
with a smaller imager format like the sensor on the 10D/20D/DRebel, a lens would give a smaller FOV on such cameras as it would on a larger format. this is known as the crop factor (which tends to lead to very long threads, especially when mixed with other technical terms, LOL).
good luck and welcome to the forum!
-alex
brentw505 wrote:
i never really knew what those numbers really meant... i just thought that it was the length of the lens... didnt know if every 25mm lens has the same field of view as any other 25mm lens
