So, I'm getting ready to order the 5D Mk II, and I was wondering...
How sealed is the 5D2, compared to the 40D? (Both, when using L lenses)
Tumeg Goldmember 1,823 posts Joined Nov 2007 Location: Orange County, California More info | Oct 15, 2009 23:26 | #1 So, I'm getting ready to order the 5D Mk II, and I was wondering... | Canon 5D Mk II | Canon 17-40MM F/4L | Canon 50MM F/1.4 | Canon 85MM F/1.8 | Canon 580EX II |
Tsmith Formerly known as Bluedog_XT 10,429 posts Likes: 26 Joined Jul 2005 Location: South_the 601 More info | Oct 15, 2009 23:41 | #2 Only sealing the 40D has is on the battery door and that's questionable. 5D2 has sealing throughout the body but it ain't waterproof.
Raginl3ull Senior Member 427 posts Likes: 1 Joined Mar 2009 More info | Oct 16, 2009 01:06 | #3 Tsmith wrote in post #8831779 Only sealing the 40D has is on the battery door and that's questionable. 5D2 has sealing throughout the body but it ain't waterproof. None of the bodies are waterproof. Moisture and dust resistant is more appropriate. | Canon 5D Mark II + BG-E6 | Canon 7D | 24-105mm F4 L IS | 70-200mm F4 L IS| 50mm F1.4 | 28-135mm IS F3.5-56 | 430EX II | 580EX II |
davidinjp Senior Member 324 posts Joined Feb 2008 Location: Tokyo More info | Oct 16, 2009 04:23 | #4 PermanentlyUsed my 5D2 in the rain many times. No problems. Just keep a small towel on top to soak up the moisture, rather than plastic bags or rain covers that tend to cause the moisture and condensation to build up on the body.
gjl711 Wait.. you can't unkill your own kill. 57,729 posts Likes: 4064 Joined Aug 2006 Location: Deep in the heart of Texas More info | Oct 16, 2009 07:34 | #5 I wouldn't put a lot of trust in any of the non-1D weather sealing ability. There have been too many stories posted where a camera died because it got wet. A while back one gent got splashed taking a pic of breaking surf and the result was a dead 5DII. Also, even on the newer cameras water damage is not covered by Canon even if on warranty. That said, I have taken all my cameras outside in the rain and used various techniques to keep as much water off them as possible such as shooting under an umbrella, keeping the camera under my shirt until the moment I want to take a pic, and toweling off the body. So far no dead cameras but then again I am very water concious and get it off as soon as I can. Not sure why, but call me JJ.
RiaGurl Goldmember 1,857 posts Joined Sep 2008 Location: somewhere south of the arctic circle More info | 5d2 is less sealed than the 7d:p VictoRia
gjl711 Wait.. you can't unkill your own kill. 57,729 posts Likes: 4064 Joined Aug 2006 Location: Deep in the heart of Texas More info | Oct 16, 2009 07:54 | #7 I guess the question to really ask yourself is: Not sure why, but call me JJ.
datadump Goldmember 1,932 posts Joined Oct 2007 Location: Canada More info | Oct 16, 2009 08:03 | #8 davidinjp wrote in post #8832670 Used my 5D2 in the rain many times. No problems. Just keep a small towel on top to soak up the moisture, rather than plastic bags or rain covers that tend to cause the moisture and condensation to build up on the body.
datadump
Oct 16, 2009 14:04 | #9 I live in Southern California, so there is no "extreme" weather. | Canon 5D Mk II | Canon 17-40MM F/4L | Canon 50MM F/1.4 | Canon 85MM F/1.8 | Canon 580EX II |
Nervous Senior Member 372 posts Joined Oct 2008 More info | Oct 16, 2009 14:08 | #10 Here is how: https://photography-on-the.net/forum/showthread.php?t=743745 7D | 5D classic | EF-S 10-22 | EF 24-105 L IS | EF 70-300 IS USM | EF 85/1.8 | EF 50/1.8 II | Sigma 24-60/2.8 | Tamron 90/2.8 | 580EXII | 2x 420EX | 055XPro + 488RC2
nicksan Man I Like to Fart 24,738 posts Likes: 53 Joined Oct 2006 Location: NYC More info | Oct 16, 2009 14:29 | #11 RiaGurl wrote in post #8833204 5d2 is less sealed than the 7d:p Let's not go too far. They both use the same kind of "foam" type material as seals. The 1DMKIII uses rubber seals and gaskets.
mrkgoo Goldmember 2,289 posts Joined Aug 2006 More info | Oct 16, 2009 14:42 | #12 You know, there's a little rubber seal on the lens mount of a weather-proofed lens. Why not have that seal on the body instead, so that ALL lenses at least have that seal? Or would that be encroaching on the realm of 'L' lenses?
jorl Senior Member 594 posts Joined Jul 2007 Location: Sarnia, Ontario, Canada More info | Oct 16, 2009 14:55 | #13 i wouldnt trust the sealing. just ****ty foam sealing i think anyways. FOR SALE: Brand new Nikon 50mm 1.4G - Msg me for details
RiaGurl Goldmember 1,857 posts Joined Sep 2008 Location: somewhere south of the arctic circle More info | Oct 16, 2009 14:58 | #14 mrkgoo wrote in post #8835570 You know, there's a little rubber seal on the lens mount of a weather-proofed lens. Why not have that seal on the body instead, so that ALL lenses at least have that seal? Or would that be encroaching on the realm of 'L' lenses? Arguably, it's like putting in IS on the sensor/body, but at least, they say, that IS is much more efficient in the lens (and has other advantages like seeing that in your viewfinder). i bet someone could manufacture a rubber seal to fit around eos bodies that could be applied with aspecial glue for really cheap. that person would be rich. and it would be cheap to make. i'd buy one for $10. VictoRia
RDKirk Adorama says I'm "packed." More info | Oct 16, 2009 22:23 | #15 mrkgoo wrote in post #8835570 You know, there's a little rubber seal on the lens mount of a weather-proofed lens. Why not have that seal on the body instead, so that ALL lenses at least have that seal? Or would that be encroaching on the realm of 'L' lenses? Arguably, it's like putting in IS on the sensor/body, but at least, they say, that IS is much more efficient in the lens (and has other advantages like seeing that in your viewfinder). The 1-series cameras have a mating surface on the mount that takes advantage of the L lens gasket. TANSTAAFL--The Only Unbreakable Rule in Photography
| Latest registered member is MWCarlsson 1495 guests, 125 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
