Thread started 16 Oct 2009 (Friday) 00:59
Recovering Files off Bad Ex HD
justincase724
Oct 16, 2009 00:59 |  #1
I did a quick search and found a few useful threads on recovering data from a bad external hard drive, but I'm confused by the first few solutions I found by searching on the net. The first four or so solution I found on the net said to "put the drive in the freezer overnight (in a plastic bag to keep out moisture), and when you plug it back in to your computer, pull the files out as quick as you can". To me, that doesn't sound like a smart thing to do, but it seems to be a common solution on the net. Anybody have any experience with this technique? Any other solutions you can suggest?
FLICKr (external link) GEAR
Todd ­ Lambert
I don't like titles
Oct 16, 2009 01:06 |  #2
That actually does work... believe it or not. However, because of the moisture, it is the very last resort you can take. I've done it and I was able to successfully retrieve files that I could not any other way.
That said, you won't have a very long time until it warms up, so don't think that you're going to be able to clone the whole drive. Your going to have a matter of minutes, so get what you can get, quickly.
Did I say that this is the last resort.. it is .. don't do this until you've tried everything else.
justincase724
Oct 16, 2009 12:35 as a reply to  @ Todd Lambert's post |  #3
Thanks for the heads up. I've got a new HD and eSATA cable coming on monday, so I'll try pulling the drives out of the bad ex hd and hooking them up directly to the computer, see if I can't pull the files out that way.
Todd ­ Lambert
I don't like titles
Oct 16, 2009 12:44 |  #4
If it's in an external case, most likely it is the case that is the problem and not the hard drive.
Normally hard drives don't suddenly die. There is usually warning signs, heat, noise, or weird glitches.
If the drive truly did die instantly, most likely the only recourse you will have will be expensive recovery services. It probably means the platters touched the arm, or something else bad happened.
If the drive is just going bad, it will make sounds, grinding noise, etc.. which is often the bearings in the platter cylinder. This is a precursor to it's eventual death, but you can beat it to the punch and get your stuff off.
Most external cases are made with the utmost of cheap crappy parts (even some of the expensive cases) so when a drive dies suddenly, most times it's the power unit of the case and not the drive itself.
Anyways, good luck.. and if you do have to resort to the cold treatment, report back and let us know how it goes.
justincase724
Oct 16, 2009 13:43 as a reply to  @ Todd Lambert's post |  #5
That's what I'm thinking - just the case that's gone bad. The whole thing powers up and I can hear each of the drives start to spin without any wierd noises, but it doesn't communicate correctly with the computer. When it's hooked up, the computer freezes up trying to read the HD and it won't even show that the drive is connected. Then when I disconnect the HD, it quickly shows the drive connected, then goes away, then the computer unfreezes and works properly.
Another question on hooking the drives up directly to the MB. I kind of tried it once (long story) and the drive showed up on the Device Manager, but I couldn't find any way to open it. Any chance that the drives can't be accessed without being connected to the components in the case, or that they can't be accessed seperately (there's two drives in total)?
Todd ­ Lambert
I don't like titles
Oct 16, 2009 16:54 |  #6
No, there should only be one drive, and unless there is some sort of formatting done to it, it should show up as a normal hard drive. (unless it's been partitioned - basically turned into two or more drives) in which case, it would show up as multiple drives.
jwoods85
Oct 16, 2009 19:52 |  #7
if it's external, why not put it in the freezer , ziplocked really tight/taped... and have it plugged into the computer? You'll have a longer time to pull files off
|| 5D mk II || Sigma 24-70 2.8 II || Sigma 50 1.4 || 50 f1.8 || Sigma 70-200 2.8 || 580EXII with battery pack || http://www.jowofoto.co​m (external link)
dovaka
Joined Sep 2009
Oct 16, 2009 20:05 |  #8
jwoods85 wrote in post #8837143 (external link)
ive actually got a pic somewhere with a motherboard on top of a mini fridge with a bunch of cables going into the freezer when i was trying to recover files for a friend of mine
i own way to much crap to list it all here and try to keep it up to date
jwoods85
Oct 16, 2009 20:17 |  #9
dovaka wrote in post #8837200 (external link)
lmao. genious.
justincase724
Oct 17, 2009 01:42 |  #10
Ha, that would be a fun picture to see. So, did it actually work to get all the files back?
Deejayry
Oct 17, 2009 14:19 |  #11
Good idea, i'd try that first before ripping the enclosure apart,
My previous computer was pretty much a fridge, the CPU, GPU, NB & RAM were all water chilled (using a beer chiller) and the rest of the case had cold air pumped through, the cpu never got hotter than 2 Celsius.
50d & BG-E2N, 10d & BG-ED3, EF 24-85mm f/3.5-4.5 USM. Tokina 11-16mm f/2.8 DX Pro, Speedlite 580EX II
Manual lenses: 135mm f/2.8, 200mm f/3.5, 300mm f/5.5 & 400mm f/6.3
Full Kit List
dovaka
Joined Sep 2009
Oct 17, 2009 19:45 |  #12
justincase724 wrote in post #8838436 (external link)
i got about 98% of them off but i got 100% of his critical stuff off and before freezing it would only run for maybe a minute or so
1,519 views & 0 likes for this thread
Latest registered member is stapelt
1049 guests, 324 members online
