Thread started 31 May 2005 (Tuesday) 18:20
Lens Cleaning Question
NetherChris
May 31, 2005 18:20 |  #1
dSLR newbie here. Just picked up a Digital Rebel XT and noticed some lovely smudges on the lens that simply would not come out with a microfiber cloth. Ran out and bought a camera cleaning kit, read directions, and...
Wound up with a small amount of lens cleaning fluid underneath the 18-55mm kit lens. Searched all over and unable to find out exactly what to do to rectify this. Not sure if it will evaporate on its own, if the lens must be returned, etc...
Any help is greatly appreciated.
ddelallata
May 31, 2005 18:37 |  #2
Do you mean that you got some cleaning solution on the inside of the front element? That doesn't sound good, but if it is not too much, I doubt that it will affect image quality.
Dr. David de la Llata
_____________
Canon 20D
BG-E2 Battery Grip
Canon SpeedLite 430 EX
Canon EF 1.4X II
Canon EF-S 10-22mm F/3.5-4.5 USM
Canon EF 50mm F/1.4 USM
Canon EF 100mm F/2.8 MACRO USM
Canon EF 24-70mm F/2.8 L USM
Canon EF 70-200mm F/2.8 L USM
Olympus C-2020 (for infrared work)
NetherChris
May 31, 2005 18:39 |  #3
Yes, that's what I meant. It seems to have gotten underneath the front element.
Poco
May 31, 2005 18:41 |  #4
The lens cleaning solution should evaporate on its own. At worst it might leave a bit of a film if it is not pure alcohol. If you can't see it then it should be fine. Next time use less cleaning solution.
http://notions.okuda.c​a (external link)
Canon Digital Rebel XT
Canon S400 + underwater case
EF 28-105mm f/3.5-4.5 II USM
EF 50mm f/1.8 II
EF 70-200mm f/4L USM
Etrex Legend GPS for geotagging
NetherChris
May 31, 2005 18:49 as a reply to  @ Poco's post |  #5
Thanks for the replies. Lesson well learned. Just glad it was the kit lens and not an expensive one :)
1,279 views & 0 likes for this thread, 3 members have posted to it.
1880 guests, 107 members online
