Thread started 16 Oct 2009 (Friday) 07:18
DPP Summit
spcalan
Oct 16, 2009 07:18 |  #1
From this moment on..
This shall be the DPP Summit of ideas, tricks, tips, questions, and anything relating DPP.
Let this be THE DPP source for knowledge.bw!
Alan Hicks
Canon 5D w/Grip/ Canon Rebel 6mp ( back-up ) - Sold
28-135 USM IS / 50mm 1.4 / - Sold
Bunches of Lexar Pro 2GB/4Gb cards - Still got
spcalan
Oct 16, 2009 08:04 |  #2
Hmm.
Any hints,tricks, tips, questions?
Alan Hicks
HankScorpio
Oct 16, 2009 13:55 |  #3
Use Lightroom ;)
Just kidding.
My collection of boxes with holes (external link)
EXIF semper intacta.
Gort! Klaatu barada nikto.
Zazoh
Oct 16, 2009 21:41 |  #4
Quick Culling -- Open DPP and go to the folder you want to view. Go to Tools | Quick Check go to full screen mode. Use the arrows to scroll through images use the numbers to rate the photos, I use 3 for trash and 1 for keepers two maybes.
When you hit the end, press esc and go back to the normal view, go to edit, select check mark 3s and delete.
Process your 1's then output. THen go back to your two's and rate as either 1 or 3. After you process yours first ones, you will know what you want.
Rinse, lather repeat.
I can do Hundreds of photos in minutes this way.
A Camera - A Lens -- Gear Doesn't Matter
dave_bass5
Gallery: 34 photos
Oct 17, 2009 08:09 |  #5
Zazoh wrote in post #8837647 (external link)
Quick Culling -- Open DPP and go to the folder you want to view. Go to Tools | Quick Check go to full screen mode. Use the arrows to scroll through images .
Cheers. For years ive struggled to use DPP as a RAW viewer for multiple photos, i didnt know you could do it this way. Very handy to know.
Dave.
Gallery@http://www.flickr.com/​photos/davebass5/ (external link)
Canon R7 | Canon EOS-M50 | Canon 24-70 f/2.8L MKII | 70-300L | 135L f/2.0 | EF-S 10-18 | 40 f/2.8 STM | 35mm f/2 IS | Canon S110 | Fuji F31FD | Canon 580EXII, 270EXII | Yongnuo YN-622C Triggers.
snowyowl13
Oct 17, 2009 09:17 |  #6
That's the same approach as I use. I generally find that all my #2s become #3s when I revisit them. if they weren't good enough to make the first cut then they are rarely worth saving.
windpig
Chopped liver
Oct 17, 2009 13:14 |  #7
Zazoh
Great tip!
Go ahead, spin the wheel.
Mountain ­ Drifter
Oct 18, 2009 09:24 as a reply to  @ windpig's post |  #8
Quick question regarding DPP and sharpness. I'm brand new to shooting RAW and DPP so I hope I'm missing something easy.
I've been shooting RAW + Jpeg (with a G11) and looking at the two side by side in DPP the RAW capture is sharper. I've read this may be from some of the NR in the Jpeg engine. So without making any adjustments and simply converting the RAW to Jpeg the image appears to lose sharpness. Is this just because of the loss of information or is something else going on?
My Smugmug (external link)
Zazoh
Oct 18, 2009 09:38 |  #9
Mountain Drifter wrote in post #8844281 (external link)
DPP will show the camera settings for RAW files, so if you have sharpness on 3 in camera, it will be the same in DPP.
What settings are you using for export? Full Quality or something less. And, where are you viewing them back? Print, DPP, other program?
There may be compression going on, but I haven't witnessed, in my experience. Hmmm
patwill
Oct 18, 2009 10:25 |  #10
That's almost the same as the way I use DPP to cull large batches (250-500) of RAW files. However, I have been doing this in the regular maximized window of the Quick Check tool instead of the Full Screen. Are there keyboard equivilants to all the buttons (clear, Image Info, rotate, AF point, etc.) available in FS?
After deleting all the 3s, I will move all the 1s to a subfolder named simply "1s" before I do the individual file edits. I think that DPP works a lot faster when you don't have as many files in the folder you are working in.
Mountain ­ Drifter
Oct 18, 2009 10:33 |  #11
Zazoh wrote in post #8844346 (external link)
I download the pictures from the camera with Canon utilities and then open DPP. Then I select both the RAW and Jpeg version of the the same photo and open the image edit window. With the two thumbnails on the side I can click back and forth and see the difference in sharpness. At this point if I convert and save the Raw to a Jpeg the new Jpeg compares to the Jpeg that came straight out of the camera. What I'm trying to figure out is if DPP is applying another action to this in the conversion process that I can disable or if that's just what the compression is doing. It doesn't seem right that if I like the RAW image that after I convert to Jpeg that I would need to sharpen it to make it look the same.
I'm comparing all of the views on my monitor, in DPP at the same viewing size.
dave_bass5
Gallery: 34 photos
Oct 18, 2009 10:59 |  #12
I believe that DPP uses a different logarithm to the camera. In the past if you wanted to get the same processed JPG as the camera produces its best to do it in the Canon RIT that comes with ZoomBrowser.
Dave.
patwill
Oct 18, 2009 11:09 |  #13
Mountain Drifter wrote in post #8844571 (external link)
Are you aware that the slider for Luminance noise reduction defaults to a setting of 2? When you convert your RAW file to a second jpg, it will have some noise reduction applied to it, and will therefore lose some detail which may need to be recovered by applying a little sharpening. You can change this to zero, or any other setting, by using the Preferences dialog. It's at the bottom of the Tool palette tab.
Mountain ­ Drifter
Oct 18, 2009 11:10 |  #14
dave_bass5 wrote in post #8844675 (external link)
I don't want the Jpeg the same as it's processed from the camera. I really like the way it looks opening the RAW file in DPP. Is that where the different logarithm would take place? If so I like it. I want to keep the same level of sharpness as it gets converted from CR2 to Jpeg in DPP, and right now it doesn't. Is that normal?
Mountain ­ Drifter
Oct 18, 2009 11:22 |  #15
patwill wrote in post #8844721 (external link)
I've put those sliders to zero and still notice a difference.
I suppose I should ask an even more basic question (since I'm new to RAW), If viewed at the same size (800x600) should a RAW converted to Jpeg look exactly the same? Or do I need to account for some changes?
38,067 views & 0 likes for this thread, 46 members have posted to it.
DPP Summit
1060 guests, 104 members online
