Thread started 16 Oct 2009 (Friday) 17:44
Camera settings for cheerleading shoot
ReDDoG
Oct 16, 2009 17:44 |  #1
Hello,my niece is doing a cheerleading competition saturday.It will indoors in a fairly well lighted gym.Considering my lenses which settings generaly speaking would be a good start.I dont think ill need my flashgun because ill be a certain distance away.
AV stop down to f10 or so for sharpness ?AL servo ?
Not sure.My sharpness is fairly good upclose but sometimes its blurry after cropping distance shots.I usually shot at the fastest F # for my lenses.Im sure some shots will be like when they jump around /toss a girl in the air type action.
Thanks for any help.
Rebel XSI -7D- 18-55mm - 10-20 mm Sigma - 55-250 mm - 580 II flash - Cactus V5 -Sigma 17-50 2.8 OS - 50 mm 1.8 -70-200 2.8 IS II :rolleyes:
JeffreyG
Gallery: 42 photos
Oct 16, 2009 17:50 |  #2
ReDDoG wrote in post #8836596 (external link)
Well lit gym? What is that? A really, really good HS gym is typically EV7. That nets you ISO3200, f/2 and 1/800 for instance.
A Div 1A NCAA gym might be as bright as EV 9. That would allow you to shoot at ISO1600 with an f/2.8 zoom.
I've never shot any action slower than f/2.8 in a gym, and I usually have to use primes because I need f/2 to stay above 1/800 at ISO3200.
IMO f/10 is totally hopeless....it doesn't even work with strobes because you would never have enough strobe power at that aperture.
If you have lenses of f/2.8 and faster at the lengths you need you can shoot the action shots. Otherwise set the camera to ISO1600 - 3200 and try and grab the cheerleaders when they are paused in a set.
ReDDoG
Oct 16, 2009 18:01 as a reply to  @ JeffreyG's post |  #3
My gear is under my post.All my lenses are f4 and up variety.
Besides setting ISO to 1600 which mode should i shoot in?For the faster type shots.Should i use single shot or AL servo?
AV or M ?I realize i dont have a fast setup im just trying to make the best of my current setup.
Cesium
Oct 16, 2009 18:51 |  #4
Use the 55-250, Av mode (manual if you're comfortable with it), AI Servo, aperture as wide as it goes ( 4 - 5.6, depending on focus length), iso 1600 or as high as you'll need to freeze motion. Lens IS should be on. This is the best you'll get if you're not using flash. (or shooting raw and pushing in PP)
JeffreyG
Gallery: 42 photos
Oct 16, 2009 20:31 |  #5
ReDDoG wrote in post #8836700 (external link)
OK, here is my take based on your gear.
You are going to have to use the 55-250 for the reach and you will most likely be into the f/5.6 max range for the shots.
A 'great' gym is EV9 and typical is more like EV7. DIMnasiums are as bad as EV5.
At EV9 you could manage ISO1600, f/5.6 and 1/250 which will be adequate for when the cheerleaders are posed in a static position. Use the IS.
If the gym is more like EV7 (which will appear to be bright to your eyes) then things get very hard very fast. You will have to push the camera to an ISO 3200 equivalent (does the XSi have an 'H' setting?) and then shoot at a miserable f/5.6 and 1/125. Motion blur will be your bane, plus a pretty healthy level of noise. All in all though, this is the best you can likely do.
kitacanon
Oct 16, 2009 20:38 |  #6
Check out:
https://photography-on-the.net …y.php?s=&dayspr​une=&f=117
https://photography-on-the.net …ay.php?s=&daysp​rune=&f=30
My Canon kit 450D/s90; Canon lenses 18-55 IS, 70-210/3.5-4.5....Nikon kit: D610; 28-105/3.5-4.5, 75-300/4.5-5.6 AF, 50/1.8D Nikkors, Tamron 80-210; MF Nikkors: 50/2K, 50/1.4 AI-S, 50/1.8 SeriesE, 60/2.8 Micro Nikkor (AF locked), 85mm/1.8K-AI, 105/2.5 AIS/P.C, 135/2.8K/Q.C, 180/2.8 ED, 200/4Q/AIS, 300/4.5H-AI, ++ Tamron 70-210/3.8-4, Vivitar/Kiron 28/2, ser.1 70-210/3.5, ser.1 28-90; Vivitar/Komine and Samyang 28/2.8; 35mm Nikon F/FM/FE2, Rebel 2K...HTC RE UWA camera
JHutter
Oct 16, 2009 20:50 as a reply to  @ JeffreyG's post |  #7
I agree with everyone else that you are going to find that even though the gym seems bright enough to your eyes, you are going to find it impossible to get enough light for a fast enough shutter speed to freeze action. Really, you have two choices:
1) Set your XSi to ISO 1600 and follow the good advice you've been getting to do the best you can with your gear. Keep the aperture wide open and see what you end up with. Try some different shutter speeds (even at the expense of underexposing - you can always push it later in Photoshop) to get a feel for what it takes to freeze action.
2) Give up and don't bring your camera.
I recommend choice 2, because choice 1 is guaranteed to make you run out and buy some fast glass. Of course we know you'll ignore me and go with choice 1.
70D | 15-85 IS | 28/1.8 | 40/2.8 | 50/1.8 | 60/2.8 | 100/2 | 70-200/4 IS | 200/2.8 | 430EX II
jrscls
Gallery: 158 photos
Oct 16, 2009 21:09 |  #8
Your current lenses aren't going to cut it for indoor cheer. For a crop body, you should get a 85mm f1.8 (or 100mm f2) lens and shoot at ISO 1600 at f2. Try to achieve a shutter speed of at least 1/400, preferably faster. I usually set white balance ahead of time and always use AI Servo mode. Here is an example of such as shot with 85mm f1.8 on a 40D-
Sony A1, 24-70mm f/2.8 GM II, 70-200mm F/2.8 GM OSS II, 200-600mm f/5.6-6.3 G OSS, 35mm f/1.4 GM, Viltrox 16mm f/1.8, 1.4X TC, Flashpoint flashes
whuband
Oct 17, 2009 07:44 |  #9
IMHO you need to use your flash. Typical gym + your equipment = nothing. Not trying to be harsh. It's obviously something you don't photograph often or you would have different lenses. Use that flash and you'll get some decent pics.
1D4, 6D, 7D2, Sony a6000 with Sony16-70, Rokinon 12mmf2, Canon lenses: 17-40L, 17-55 f2.8, 10-22, 50mm 1.4, 85mm 1.8, 70-200mm IS 2.8, 300mm 2.8 IS, 580EXII (3), 430EX, Alien Bees.
ReDDoG
Oct 17, 2009 17:37 as a reply to  @ whuband's post |  #10
No i was doing the best i could with the glass i had.Didnt need the flash today as it turns out.Gym had good lighting.Pics turned out good.Main problem was capturing the still shot of a jumping cheerleader.lol.Im no pro nor have the money to buy the great glass.
Dont agree with this."Typical gym + your equipment = nothing."
As far as a dimly lite gym i think i understand your point.I dont think my gear is by no means the best by a long shot.But from where i had to sit.i was fairly happy.
9,356 views & 0 likes for this thread, 7 members have posted to it and it is followed by 2 members.
1182 guests, 181 members online
