Thread started 16 Oct 2009 (Friday) 21:22
Latest Info From Innovatronix (soon to be announced on site)
TMR ­ Design
Joined Feb 2006
Oct 16, 2009 21:22 |  #1
I've got the latest info from Innovatronix from my 'source' and this information is going to be announced on site and product info inquiries will be addressed by Innovatronix shortly.
- After getting many complaints from customers about the fans running while the XT is charging, there is an update to older units and a change to the XT's in future production that disables the cooling fans during the charge cycle. The side effect of this change is that there is a slightly longer charge cycle which is now 4 to 5 hours rather than the approximate 3 hours it currently takes.
I believe it's a free upgrade but if you're a US customer I can't imagine it's worth the cost of shipping unless the noise from the cooling fan is completely intolerable.
- Regarding the use and compatibility of multi-voltage strobes... unfortunately Innovatronix made the decision not to upgrade the existing Explorer XT to support multi-voltage strobes but they are releasing a new version of the XT, which will be called the XT SE (special edition) and produced in limited quantities as they see the demand. The XT SE is said to support the following strobes:
Elinchrom BXRi 250 and 500
Elinchrom 400BX
Elinchrom D-Lite's
Hensel Integra Pro 500 Plus
Profoto Compact 600R
Calumet Genesis 200 and 400
The XT SE should be released sometime in early November, 2009.
Robert
TMR ­ Design
Joined Feb 2006
Oct 16, 2009 23:33 |  #2
I'm going to bump this because I know there are many people interested in using Elinchrom and some other multi-voltage strobes with the Innovatronix portable battery.
Robert
tsaros
Oct 17, 2009 07:31 as a reply to  @ TMR Design's post |  #3
Thank you for the info :)
// Andreas.
Eos 30D + grip + rrs, Eos 7D + grip + rrs
Sigma 10-20EX, 24-70EX and 70-200EX Macro,30 1.4 EX, 50 1.4 EX, 580EX,430EX II, Manfrotto MF3, 468MG + rss, Skyports.
medic583
Oct 17, 2009 07:54 |  #4
Elinchrom 400BX's.... ok... now you have my rapt attention :)
Thanks Robert, I'll definately be looking into one of the new versions when they come out as I can't wait to try out my strobes on battery power.
Dennis
"Old enough to know better, young enough to learn a heck of a lot more"
hawk911
Oct 17, 2009 13:31 |  #5
damn- so that means I either keep my existing and buy another one for $450, or sell my old and but the new, but still need some additional cash to make up the short.
Gee- thx Robert :|
HAWK Photography Gallery (external link) FB Fan page (external link)|_My gear: 5d3, 70D & 40D (all gripped), 580exII, 550ex, Canon 24-70 L & 85 f1.8, 50mm f1.4; Tamron 70-200 SP Di VC, Canon 18-55, Sigma 1.4xtc; Elinchrom Whore, Skyport triggers, Speedotron BD and Kacey Grid, Vagabond minis
pops77
Oct 17, 2009 14:25 as a reply to  @ hawk911's post |  #6
Hi Robert and thanks for posting this information. I was just on the Innovatronix web page and did not see that the SE had been tested with the Calumet Genesis Series of strobes. Are we sure that the two will sing in harmony? Cause frankly, I want one.
H2OSkier
Oct 17, 2009 14:52 as a reply to  @ pops77's post |  #7
Robert,
I quick google found this (external link) on the Innovatronix site. It does not mention the 400BX. Any idea if they will be added or just unofficially work ?
Ken
TMR ­ Design
Joined Feb 2006
Oct 17, 2009 14:53 |  #8
pops77 wrote in post #8840630 (external link)
Based on what I was told and the specific questions I asked, the Calumet Genesis strobes should be completely compatible, as they are very similar in design to the BXRi's.
The compatibility chart shown on the Innovatronix site is only representing strobes that have been tested. The information I was given was based on the engineering and design on of the strobes, and knowing the design, it's easy to predict compatibility, knowing how other strobes of similar design will work.
They won't list a strobe as compatible if it hasn't physically been tested but they can safely predict compatibility.
Glen will be out of the office for about 30 days so I'm not sure if Gary or others at Innovatronix are told to give the stock answer and defer to the compatibility chart of if they'll give you undocumented information as I was given.
My guess is that the info I got was accurate and if the new SE is addressing the issue of multi-voltage strobes and are listing the brands and models that they are, then I think it's a very safe bet that other multi-voltage strobes will work as well.
I know that we'd all like to have a definitive answer and see it on the site but I can understand that they can't (or won't) run out and buy every strobe out there, so the focus is on key brands and models that can more or less tell them if other strobes of the same design will work.
Robert
TMR ­ Design
Joined Feb 2006
Oct 17, 2009 14:54 |  #9
H2OSkier wrote in post #8840726 (external link)
Robert,
Ken
Hi Ken,
You hit the nail on the head. Based on other strobes of similar design's working, these others will 'unofficially work', and although it's not what any of use would like to hear, I'm sure that if you found it was not compatible they would take it back and more than likely cover the shipping.
Robert
fivegallon
Joined Sep 2004
Oct 17, 2009 16:00 |  #10
Hi Robert, seeing as you have friends on the "inside" there maybe you can suggest a slight re-design for the output sockets on the Explorer XT.
Currently anyone using "UK Style" plugs or "Australian" plugs is risking cable damage unless the entire unit is raised off the ground. This could eventually lead to exposed wires/electrocution risk.
Options would be to invert the output socket or to put some stubby legs on the base.
Not sure if anyone else has noticed this.
I will come back with a pic soon ( 5am here and coffee has not taken hold yet)
Apologies for being off topic
Info
roman_t
Oct 17, 2009 16:17 |  #11
thank you, robert, for info.
i am going to purchase explorer for next summer to use it with my dlites2 kit and its great to hear about upgrades
TMR ­ Design
Joined Feb 2006
Oct 17, 2009 17:00 |  #12
fivegallon wrote in post #8841038 (external link)
Please post the picture so I can forward it to the engineering department and see if something can be done. It always depends on the complexity of the modification or upgrade as to whether they will implement it but they do take my feedback into consideration whenever possible.
I'll do what I can.
Robert
fivegallon
Joined Sep 2004
Oct 17, 2009 17:19 |  #13
TMR Design wrote in post #8841302 (external link)
I'll do what I can.
Pics are here: http://fivegallon.foto​pic.net/c1769441.html (external link)
Info
TMR ­ Design
Joined Feb 2006
Oct 17, 2009 17:37 |  #14
Ahh, I see. Bad design. Are all the plugs at 90 degree angles or are there some that come straight out?
Robert
fivegallon
Joined Sep 2004
Oct 17, 2009 17:43 |  #15
TMR Design wrote in post #8841460 (external link)
I have both the UK and Australian plugs and they both suffer the same issue. I'm positive all the UK plugs are at 90 but it may be possible to find some Australian plugs that are straight.
The UK ones were supplied with the FX400's i purchased in Singapore. The Oz cables were also purchased in Singapore.
A 180 degree turn around may see too much weight from the cable pull down on the plug causing it to come out slightly (also:the left one would nearly interfere with the on/off switch, the right one could obscure the indication lamps)
A 90 degree turn would be possible with both facing "outwards".
Not sure if its possible to raise the outlet position.
Some short legs would be the simplest.
I currently use a couple pieces of 4x2 to raise the whole unit off the deck.
Info
8,845 views & 0 likes for this thread, 19 members have posted to it.
1608 guests, 142 members online
