Thread started 16 Oct 2009 (Friday) 22:18
Canon 5D Concert settings.
covrc
Oct 16, 2009 22:18 |  #1
Hi All,
I am looking for some advice for shooting a concert at the House of Blues tomorrow night.
I have been using a borrowed Nikon D300 with a 2.8 70-20. I was able to borrow a buddies Canon 5D for the show.
I am looking foe any suggestions for WB settings?
I see that some choose to shoot at 'K' after adjusting the temperature in the menus. Anyone have any exposure suggestions.
I will be using Canon 'L' glass. 24-105 F4, 105mm 2.8 and a 200mm 2.8.
I am open to exposure and program settings, even though it is a Canon.
Thanks. covrc
There's Something For Everybody At Rocco's Photo Tavern.
We're Always Open.
You're Always Welcome.
Bring A Friend. Stay As Long As You'd Like. Come Back Often.
Sit Back, Relax, Put On Your Favorite Music And Have A Look Around.
irishman
Oct 16, 2009 22:29 |  #2
There will likely be a multitude of different lights/lighting, so I would just use AWB and adjust in ACR. Use a high ISO (1600) and the fastest glass you can get. You might want to leave the 24-105 at home.
6D, G9, Sigma 50 1.4, Sigma 15mm Fisheye, Sigma 50 2.8 macro, Nikon 14-24G 2.8, Canon 16-35 2.8 II, Canon 24-105 f/4 IS, Canon 70-200 2.8 IS, tripod, lights, other stuff.
bohdank
Oct 16, 2009 22:34 |  #3
The lighting should be sufficiently good to use the 24-105 at ISO 1600. Set the camera to AWB, camera to Manual, start at 1/320s, chimp until you get a good exposure in good light and don't keep changing the settings as you go along.
I (almost) never adjust the WB in post, preferring to keep the ambience of the stage lighting intact.
covrc
Oct 16, 2009 22:41 as a reply to  @ bohdank's post |  #4
Thanks for the replies.
Why would the wide zoom not be good for being in the pit. I know it is not as fast, but the wide angle should be great from there, no?
I don't know what it it to 'chimp'.
Can you explain, and thanks.
covrc
We're Always Open.
covrc
Oct 16, 2009 22:45 as a reply to  @ covrc's post |  #5
Bohdank,
Do you know photographer Lawrence Kirsh from Montreal.
Bruce Springsteen book, 'For You Bruce' just out a couple years ago and new book
'Into the Darkness' just released.
http://www.musicfoto.c​om/about (external link)
Just curious.
We're Always Open.
bohdank
Oct 16, 2009 22:49 |  #6
Chimp?: review the histogram for exposure and watch the LCD image for blinkies (blown out highlights).
No WB adjustmemt, post.
IMAGE: http://www.bwkphotography.com/photos/624916794_3V6NH-M.jpg
Here is 17mm on the 5D. I have very few UW event shots this wide.
IMAGE: http://www.bwkphotography.com/photos/624906316_xiyYm-M.jpg
covrc
Oct 16, 2009 22:56 as a reply to  @ bohdank's post |  #7
Thanks, so stay at 320 waiting for the better light and adjust the exposure accordingly.
Metering, spot, Partial, eval or center weighted?
Sorry if I am being a pain, I have a 12 hours to get ready for a shoot with the new camera I have never used.
I appreciate it.
Rocco
Great shot of Nora.
We're Always Open.
bohdank
Oct 16, 2009 23:09 |  #8
I now start at ISO1600, 1/320 f4. Seems to work in lots of venues I shoot. Sometimes I do have to go to 1/250s.
Get there while the lighting is being setup. The lighting, center spot will be adjusted and aimed with a roadie usually standing there, adjusting a mike stand. Spot meter off his face and actually take a shot. Check for overexposure of the face. The rest of the image doesn't matter, imo. Change the settings, if needed and shoot again. If no roadie, find something on the stage in the main lighting and meter off that. Find something neutral in color. There is always something. Do this with the camera in Manual.
Once you think you have it right, wait till the show starts. Get as many shots as you can in to get a comfort level before it actually does start. Once you actually are shooting the show, check the first few images for exposure. Histogram and blinkies. Reading a Histogram requires some experience, imo.
I would also adjust the LCD brightness before hand to more closely mimic what the real image will look like when importrd into PP software. You can do this at home. Having the LCD too bright or too dark may make you doubt the Histogram.
I pretty much don't do much preparation anymore other than the spot meter routine, a couple of chimps I am usually good to go. I will review some shots, when I get a chance, during a show and make some minor adjustments if I need to but I prettyy much get it right from the get go.
Good luck and let us know how it goes.
PS: Don't go chasing the perfect exposure after every shot. It's a waste of time since the lighting will be constantly changing.
Obtong
Oct 16, 2009 23:14 |  #9
Hi. I've taken pictures at concerts, plays, and other stage events with the 5D and 24-105L combination. I typically set my ISO according to the needs of the event. On the 5D I never hesitate using an ISO of 1600 if it gets me the shot as I'd rather have a noisy picture than a blurry one due to camera shake. When the performance is pretty static (like a classical concert) I often use a lower ISO and slower shutter speed, but for dance or rock concerts I will go 1600 or higher. I usually set my WB to Tungsten so that if I need to a batch WB fix, all the pictures will be corrected with the same WB. I used to used Auto WB, but found myself having to tweak each picture separately. I find using spot metering for stage events very useful, even if shooting in P mode.
~Dom
Digital: 6D, 5D, 50mm f/1.8 Mk 1, 85mm f/1.8, 17-40L, 24-105L, 70-200L f/4, 550EX, 580EX ii (2), 430EZ (2)
Film: AE-1, A-1, M6, Kowa Super 66
Deckham
Oct 16, 2009 23:21 |  #10
Some examples with EXIF intact.
http://MarkGerman.zenf​olio.com/p1006981458/s​lideshow (external link)
Lulu Clake (external link)
Zenfolio  (external link)
tfd888
Oct 17, 2009 00:18 |  #11
I would try to shoot manual but at times with quick changing light, you may have a need to shoot in AV (aperture priority) or TV (shutter priority) in which case I would use partial or center weighted metering.
Alexander R.O.
1D-Mark III ~1D-Mark II ~ 60D ~ 20D (Gripped)
(70-200mm L 2.8 IS) ~ (17-40mm L 4.0) (Sigma 24-70mm 2.8 EX DG Macro RIP) ~ (50mm 1.8 MKII) ~ (Alpex 35mm f/2.8 M42 mount) ~ (430EX II) ~ (Yongnuo YN-560 III)
My Website (external link) - My Blog (external link)
- My Flickr (external link)
4,462 views & 0 likes for this thread, 6 members have posted to it.
1284 guests, 156 members online
