I'm running LR 2.4 and PS-CS3 Extended V10.0.1 on XP
Camera files are from a 50D, imported into LR as dng
I am finding that when I edit my LR image in Photoshop (using "Edit in" link to PS) and then save the image back to LR after editing, the highlites are often now blown out in the psd saved version. Exposure was fine in the original sent to PS and I did not do any editing in PS related to exposure.
- A recent different example of a problem between the two programs & partly an experiment after noticing more of a problem:
-sent a dng file to photoshop for editing
-did no editing to the image in PS, merely saved it back to LR right away
-back in LR, I applied a B&W present to both the original LR dng and the psd-saved image
Result: the LR dng was perfect but that same psd image from Photoshop the highlights were blown out to the extreme, so much so I could not even recover it.
The saved file from Photoshop is adversely changed somehow between the programs without any editing whatsoever in PS. What could be happening and any idea how I solve this?
I've read through the forum and have checked my colour management settings, both programs are alike unless I've missed something.
When I use the "Edit In" function from LR, I do get the warning that "This version of LR may require the PS Camera Raw plug-in Version 5.4 for full compatibility" - I usually choose "open anyway" and proceed. Could this be the problem and I have to upgrade to CS4 already? Unfortunately I can't remember if this was happening with LR 1 but I feel like it was...
Any help with this would really be appreciated, I'm hesitant to use Photoshop now as it's messing with my images... thanks!
