Thread started 19 Oct 2009 (Monday) 19:51
photoflex litedome kit vs lastolite ezybox ??
powhodee
Oct 19, 2009 19:51 |  #1
anyone have any experience w/ any of these? any suggestions?
Ef 16-35mm 2.8LII, ef 24-105mmL, ef 50mm 1.8, ef 70-200mm f2.8L IS II, ef85mm 1.2L mkII, 580 exII, Nikon sb-24, 5d mkII
k.lee
Oct 19, 2009 20:43 |  #2
Also interested in this, maybe throw in those ebay 24x24 cheapies into the mix too if the OP doesn't mind :)
Kelvin
Gear list
My
Blog
external link / Flickrexternal link
bobbyz
Oct 19, 2009 21:37 |  #3
I have both but haven't done any side by side comparison.
Photoflex extra-small is quite small. eBay knock off comes with everything you need and you don't need umbrella adapter. Both have only single diffusion panel.
Fuji XT-1, 18-55mm
57hardtop
Oct 19, 2009 21:45 |  #4
I can add that the LastoLite Ezybox has an inner baffle and an outer diffusion panel.
Roger
Gear list and feedback
http://retouching-on-the.net/forums/ (external link)
TMR ­ Design
Joined Feb 2006
Oct 19, 2009 22:12 as a reply to  @ 57hardtop's post |  #5
Is there a reason you're limiting yourself to very small softboxes. Even taking a step up to a Photoflex 24" x 32" is a nice jump. The box gives you a long side that can be used vertically or horizontally for feathering and more control over falloff and wrap. Also, the 24" x 32" comes with an internal diffuser for more even lighting from center to edge. You can also get that softbox with either a white or silver interior and it can be used with the same photoflex bracket and speedring designed for a hot shoe flash and the 16" x 22" box.
I highly recommend the 24" x 32" over a 16" x 22" or a 24" square box with a single layer of diffusion.
Regarding the Lastolite box. It's nice, it does have the inner baffle, but costs a lot more than the Photoflex 24" x 32". Lastolite EZYbox's are very nice but costly.
Robert
powhodee
Oct 20, 2009 01:07 |  #6
TMR Design wrote in post #8855104 (external link)
hmm..i might consider what you're suggesting Robert, thanks! still alot of researching to go through
powhodee
Oct 20, 2009 01:14 |  #7
I was going to ask somethingbur questioned answered...
3,609 views & 0 likes for this thread, 5 members have posted to it.
1015 guests, 182 members online
