If you magnify the image, you'll note that the leaves in front of the squirrel are in focus. Agree?
Here I used the "normal" AF point, not a "spot" AF. May be the normal AF point actually focuses in a wider area than the actual rectangle, and so it locks onto the leaves which are closer than the squirrel.
Any thoughts?
![]() | HTTP response: 403 | MIME changed to 'text/html' |
