Thread started 02 Jun 2005 (Thursday) 06:46
size matters!
dioptic
Joined Jan 2005
Jun 02, 2005 06:46 |  #1
Hello,
My problem probably has a simple solution and that makes me feel pretty dumb but----I have a picture to post on this site but the system won't take it because the file size is too large. How do I reduce the file size from 2.45mb to 100kb?
Thanks.
dioptic
MCB
Joined Jun 2005
Jun 02, 2005 07:23 |  #2
Thanks.
dioptic
What program are you editing your images with before you print them? I use Photoshop, and it's super easy to just go into the "image" menu and choose "image size" then reduce the number of pixels a bit. ( you need to make is smaller than 800 x 800 pixels to post it anyway) Then when you're saving it, lower the quality a bit to help reduce the file size. Like for a jpg, you can save it as quality 3 or 4 in Photoshop and it will still look good enough online. For printing you wouldn't do that, obviously. Or use "save for web" in photoshop and let it make a nice little gif out of it.
I'm sure other programs do basically the same thing. Some are free, but I haven't used any of those in a long time. Sorry. Maybe try Picasa or IrfanView. On a Mac you can use GraphicConverter, an awsome free application. Good luck.
Baadil
Jun 02, 2005 07:27 |  #3
If you are using using Photoshop, you can simply open the image and select "Save for Web" from the file Menu. It will open a dialog box where it shows you the final file size. You have the option to reduce and increase the image quality until it reaches below 100KB.
I hope this helps. If you are not using PS, then almost every decent software allows you to select "Save As" where you can select the JPG compression/quality level.
Canon EOS 400D Xti (Poor man's 1D,) Canon 50mm 1.8 II, Sigma 55-200mm f/4-5.6, Canon 18-55mm Kit; Canon 17-55mm 2.8 IS
dioptic
Joined Jan 2005
Jun 02, 2005 07:33 as a reply to  @ Baadil's post |  #4
Baadil and MCB,
Thanks for the info.
dioptic
tupe
Gallery: 43 photos
Jun 02, 2005 07:42 |  #5
If you don't have PS, you can get a copy of PhotoImpact 6 or 7 on ebay for about US$20. You can save jpg files anywhere from 100% of original size down by 1% increments.
--Joe
Canon 20D, T2i, 100-400L IS, EF-S 18-55mm IS, EF-S 55-250mm IS, EF 50 f/1.8 II
Nikon D500, D7200, 18-55mm VR II, 55-200mm VR II, AF-P Nikkor 18-300 DX G ED VR, NIkkor AF-S 200-500mm f/5.6E ED VR
-- https://www.flickr.com​/photos/155078134@N02/ (external link)
1,657 views & 0 likes for this thread, 4 members have posted to it.
size matters!
1275 guests, 123 members online
