Thread started 21 Oct 2009 (Wednesday) 22:19
Focus on timer
30D'er
Oct 21, 2009 22:19 |  #1
Quick question for you guys in the know.
I have a 5D. Is there a way to set my camera on a timer and have it auto focus when the shutter is released? Assuming it is not refocused.
Thanks!
Gear
5D w/Grip, 30D w/grip, 24-70mm 2.8/f L, 70-200MM 2.8, L, 85MM 1.8/f, 50MM 1.8/f, 50MM 1.4/f,
580EX x 2, 580EX II, ST-E2, PIXMA PRO9500
ThinkTank 40, Airport Airstream & Belt System, Custom Bracket, and more!
apersson850
Obviously it's a good thing
Gallery: 35 photos
Oct 22, 2009 04:42 |  #2
If you use a remote controller like Canon's TC-80N3 (ridicuously expensive), it will allow you to set an arbitrary time delay, and also time between successive shots, if you want more than one. The electronics inside that remote does the half-press some seconds before actually taking the picture, to allow the camera to wake up from sleep mode and also focus, as required.
EOS Utility also allowes timed remote control, but not all features are available for older cameras, so I don't know for sure about your particular model.
Anders
30D'er
Oct 22, 2009 21:59 |  #3
Thanks, i'm gathering from other posts that this question has been asked before.
I do remember a technique that some photographers were using where they'd set the camera on a timer and throw it up in the air (yeah really).
Once when i was shooting a wedding with another photographer we experimented with this technique. This was with 1DmkIIn. And it did auto focus.
Not sure if it can even be done with a 5D or a 30D.
Gear
apersson850
Gallery: 35 photos
Oct 23, 2009 09:13 as a reply to  @ 30D'er's post |  #4
Well, as I said, any timer that uses the electrical remote control socket (N3) properly, will indeed initiate a focusing operation prior to the actual triggering of the shutter.
But if you are hurling your camera around in the air (ouch!), then I assume One Shot AF will probably not be good, as focus will have changed between focus operation and exposure.
Whether AI Servo AF, or perhaps better the new AI Servo II AF, algorithm will handle that would be interesting to know.
Anyone volunteering their 7D for hurdling?
Anyone?
Anders
787 views & 0 likes for this thread, 2 members have posted to it.
Focus on timer
1087 guests, 177 members online
