Thread started 22 Oct 2009 (Thursday) 04:30
Nodal points G11
flowe
Joined Mar 2003
Oct 22, 2009 04:30 |  #1
Hi all,
Where are the Nodal points of the G11?
I have no means to find out - who does?
Thanks in advance
flowe
Erik_L
Oct 25, 2009 16:55 |  #2
After googling "Nodal points", I am still wondering what you need to know....
How close can it focus? Focal length?
Canon EOS 1D III
Manfrotto 190X Pro B w/324RC2 "Action Head" | Canon 580EX II
Sigma 20 f/1.8 | Canon 35 f/1.4 L | Sigma 50 f/1.4 | Sigma 85 f/1.4 | Canon 135 f/2 L
Flick (external link)r
forno
Oct 25, 2009 17:02 |  #3
Erik_L wrote in post #8892360 (external link)
IIRC it is the point around which to rotate the camera so as to get the edge overlap correct in pano's
I think it is a function of sensor plane and focal length
Canon 350D -EF-S 10-22 l EF-S 17-55 l EF 50 f/1.8 l EF 70-200 2.8 IS l 430EX l
Fornography (external link)
flowe
Joined Mar 2003
Oct 26, 2009 08:50 |  #4
forno wrote in post #8892394 (external link)
forno, thanks for the clarification. Taking it one step further: the focal length is only a "handle" for the nodal point. Defined it is by lens and body design and the movement of individual lenses, shifting the optical center of the system in a way not readily known. The nodal point is given as distance along the optical axis from the tripod socket plane - with reference to the focal length, but as an entirely different number of millimeters. Consequently, the nodal information pertains to a given lens and body and would be different between say a G6 and a G10/G11.
flowe
CyberPet
Hiding Under a Rock
Oct 26, 2009 09:25 |  #5
Wouldn't the nodal point be exactly in the middle of the lens? So if the tripod mount hole is not exactly over the lens, then you have some corrections to be done, as it'll not rotate around the lens nodal point, but around the tripod mount holes nodal point.
/Petra Hall
Click here to view my geeky gear list
I shoot as much as possible in available light... sometimes, my flash is available – Joe Buissink
Erik_L
Oct 26, 2009 09:52 |  #6
I would assume that if the photo were taken from far enough away, this would be negligible.
Canon EOS 1D III
flowe
Joined Mar 2003
Oct 26, 2009 10:27 |  #7
CyberPet wrote in post #8896462 (external link)
CyberPet: "middle of the lens" is ambiguous - the nodal point lies *somewhere along the optical axis* of the lens. Then you have to take into account the height of the optical axis above camera base plane (if camera vertical), as well as the horizontal deviation of the tripod mount hole from the optical axis. Rotating the camera *truly* around the nodal point is what commercial and makeshift pano adapters are about, i.e. compensating for the deviations in all three axes.
Erik_L: Quote: "I would assume that if the photo were taken from far enough away, this would be negligible." - Right, but panos live with the depth of the subject area, and you wouldn't remain satisfied with all those flat panoramas!
flowe
CyberPet
Hiding Under a Rock
Oct 26, 2009 13:25 |  #8
Wow flowe, that totally went above my head. Thanks for the explanation. :D
/Petra Hall
forno
Oct 26, 2009 16:42 as a reply to  @ CyberPet's post |  #9
I remeber a PDF file floating around a year ago or so, that set out how to find the nodal point.
I think you need to find 2 object in line with each othe, say telephone poles, position the camera at "straight ahead". At this point you should only see 1 telephone pole with the other being hidden behind the first.
Now rotate the camera to the right, if you can still only see one telephone pole you are rotating at the nodal point.
This is from memory, dont hold me to it:lol::lol:
DaryleH
Oct 27, 2009 22:50 |  #10
forno wrote in post #8899180 (external link)
Perfect, you need to move the camera on a slider to find the perfect point, but you hit it on the nail head.
Good shooting
Daryle
Erik_L
Oct 28, 2009 12:42 |  #11
I have experienced this accidentally while shooting macros with reflective surfaces. It appears that no matter how I rotate the camera, I can see "Canon" reflecting off the glass. If is shift it just slightly and then rotate it, I can get the correct angle to lose the "Canon" from showing up.
Canon EOS 1D III
cccc
Gallery: 18 photos
Oct 30, 2009 18:56 |  #12
Erik_L wrote in post #8911736 (external link)
I think a polarizing filter will fix your problem.
flowe
Joined Mar 2003
Oct 31, 2009 06:42 as a reply to  @ cccc's post |  #13
I tried to establish G11 nodal points with a rather elaborate setup - tripod, pano head, Soligor slide and two suspended blue and red sewing threads loaded with screws in 80 and 100cm distance. But sorry, no success. Lining up and focussing straight ahead was easy, but after panning to the edges of the monitor, I haven't been able to establish conclusive results. On the wide end, the threads became almost invisible. So for the time being, I gave up. Any better ideas?
On the other hand, I've done some panos - even with handheld camera - lining up on assembly without the slightest ghosting etc. At present, I prefer "PanoramaStudio 2.0" by http://www.tshsoft.de (external link) with very pleasing results. It doesn't look like versions other than in German would be available, but a very decent user interface might help without knowing the language - a demo version is available. PanoramaStudio reads all required info from EXIF and applies correct debarrelling automatically. (BTW: what are experiences with the Canon supplied pano software?)
I feel that the nodal question is probably not very critical with the G cameras and similar (due to the narrow optical system?) Sensibly lined up on a pano head plus appropriate software will produce most satisfactory results. One more aspect: camera in vertical position makes for a larger vertical view angle and less panning between shots and therefore a less critical nodal issue.
Good pano! :smile:
flowe
denncald
Oct 31, 2009 10:08 as a reply to  @ flowe's post |  #14
Re: Canon pano software - I've had fairly good results with this software and my G9. However, I more often prefer the results achieved using the free Microsoft ICE (external link) software for panos.
Dennis
rpolitsr
Joined Jun 2005
Nov 01, 2009 22:49 |  #15
Hi flowe
I think you will do a great job with your setup, except for one thing:
You do not need thin threads to do the job, and it is better to place them near to the lens the first reference, (say, 80cm) but the second one far enough to simulate infinite. I used a 19mm aluminum tube close to the camera, I think it was at 100cm from the lens, and a tall pole (12 meters) holding a lighting fixture in the street, 50 meters from the lens. It worked, with the knowledge and guidance of Terrywoodenpic. Check one of his threads: G3 G5 accurate nodal points.
rafael
Canon EOS Rebel XT, EF-S 18-55mm f3.5-5.6 II, EF 50mm f1.8 II, EF-S 55-250mm f/4-5.6 IS STM, speedlite 430EX, basic filters set.
My photo galleries (external link)
Marketplace: PAYPAL GIFT NO LONGER ALLOWED IN POTN
7,084 views & 0 likes for this thread, 9 members have posted to it.
Nodal points G11
1825 guests, 137 members online
