Thread started 25 Oct 2009 (Sunday) 15:12
What works or doesn't with Windows 7?
RDKirk
Adorama says I'm "packed."
Joined May 2004
Oct 25, 2009 15:12 |  #1
Windows 7 64-bit.
What utilities, plug-ins, drivers, et cetera have photographers discovered could not make the transition from 32-bit XP? Or can confirm will make the transition?
I've discovered that my beloved Breeze Systems "Downloader Pro" works in 64-bit, although there is some registry juggling needed to get it to autostart when a card is plugged into a reader.
And Photoshop 32-bit plug-ins will work if you install 32-bit Photoshop in 64-bit Windows 7.
What other discoveries, happy or unhappy, have been made?
Golden ­ Hunter
Oct 25, 2009 15:19 |  #2
I found that Portraiture2 works in 64 bit CS4 but NIK plugins will only work in 32 bit CS4. This is in Windows 7, of course. Also, as someone has already posted, http://www.fastpicture​viewer.com/codecs/ (external link) , here is the codec for veiwing RAW thumbnails in Windows 7. Works like a charm.
Brent
5D Mark2 // 16-35 f4L // 70-200 f4L // 17-40 f4L // Sigma 50 f1.4//
580EX2
RDKirk
Joined May 2004
Oct 25, 2009 15:59 |  #3
Golden Hunter wrote in post #8891917 (external link)
I would recommend using the embedded preview mode--hopefully that would be able to read new Canon CR2 versions without the codec itself being updated:
Can be configured to skip raw conversion and always use embedded previews instead. Note that Canon previews are usually of lower resolution than the real image."
basroil
Oct 25, 2009 17:34 |  #4
From XP to 7, there may be some things that go wrong, but vista to 7, practically everything works as needed
lungdoc
Oct 25, 2009 20:09 |  #5
Some of our Citrix VPN stuff (for viewing Xray images from remote to our hospital for example) doesn't work quite right, but can be worked around. Otherwise for me haven't hit any snags yet.
Mark
My Smugmug (external link) Eos 7D, Canon G1X II, Canon 15-85 IS, Canon 17-85 IS, Sigma 100-300 EX IF HSM, Canon 50mm 1.8, Canon 85mm 1.8, Canon 100mm 2.8 Macro, Sigma 50-150 2.8, Sigma 1.4 EX DG , Sigma 24-70 F2.8 DG Macro, Canon EF-S 10-22, Canon 430EX,
1,522 views & 0 likes for this thread, 4 members have posted to it.
1451 guests, 128 members online
