Thread started 26 Oct 2009 (Monday) 07:38
Windows 7 64 bit and 1Ds II software
Tyreman
Oct 26, 2009 07:38 |  #1
Does anybody know if the Canon 1Ds II softwares most recent listings works with 64bit Windows 7 ?
I have looked on the Canon site and of course Vista is the last OS listed with their download drivers.Some,looks like not all 64 bit Vista stuff methinks is there.
I don't believe the firewire driver is 64 bit either
Can the Canon software run 32 bit on Windows WOW in a 64 bit OS?
Maybe you have to stay with a Windows 7 32 bit OS using Canons Vista 32 bit drivers?
Any experience or comments appreciated.:)
Cambridge, ON.
David ­ Ransley
Oct 26, 2009 08:08 |  #2
I cannot speak for the Canon 1Ds II's software, but in principle Windows 7 x64 supports the Software versions for Vista x64. If it is Vista compliant things will work fine. The only x64 bit challenge is the RAW codec to the RAW files in Explorer.
On my system this works well: https://photography-on-the.net/forum/showthre​ad.php?t=765462
DRH
efmfire
Oct 26, 2009 08:11 |  #3
I am currently running Canon (50D) 32 bit software in 64 bit Vista.
Most tech sites report that if a driver or software runs in Vista it will run in Windows 7, 32 or 64 bit. If you want to double check it, download the Windows 7 Upgrade Advisor from Microsoft and run it while the camera is attached (and on) to the computer.
HankScorpio
Oct 26, 2009 13:49 |  #4
Windows 7 will run everything except for the Firewire Driver. Canon don't make a 64bit driver and won't as the camera is discontinued. You can't use Firewire on the 1D series under Vista 64bit either.
However if you get Windows 7 Pro or Ultimate then you get windows XP compatibility mode which you can run in 32bit mode and use the Firewire.
My collection of boxes with holes (external link)
EXIF semper intacta.
Gort! Klaatu barada nikto.
Tyreman
Oct 26, 2009 14:47 as a reply to  @ HankScorpio's post |  #5
Thanks people.:)
Cambridge, ON.
EightyFive
Dec 02, 2011 06:49 as a reply to  @ Tyreman's post |  #6
I've the same problem! When I plug the camera to the pc withe the fireware cable it's recognized by Win7 but DPP, Canon Utility etc don't see it.
In the control panel the 1ds is visible but it need driver.
What can I do?
How have you solved?
I need to change the owner name and modify some personal function (for examble enable the displayzoom)
My photo blog (external link)
My Flickr Gallery (external link)
My photo album (external link)
Skylux - My amateur Astronomy blog (external link)
René ­ Damkot
Dec 02, 2011 07:34 |  #7
EightyFive wrote in post #13483707 (external link)
What can I do?
Did you try this?
HankScorpio wrote in post #8898208 (external link)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
EightyFive
Dec 02, 2011 07:58 as a reply to  @ René Damkot's post |  #8
what do you mean with enable xp compatibility mode?
in the property of file? but ...which file? i'm a bit confused..
Numenorean
Dec 02, 2011 08:08 |  #9
Only if your Win7 version is 32-bit. XP Compatability doesn't allow you to run 32-bit drivers on a 64-bit OS. XP Compatability mode is simply for running programs which may otherwise cause problems under Win7 in a special mode which may allow them to work - they may not though.
EightyFive
Dec 02, 2011 11:42 |  #10
ah :( no mine is 64bit..
I'll try the virtualmachine
3,569 views & 0 likes for this thread, 7 members have posted to it.
1032 guests, 109 members online
