Thread started 26 Oct 2009 (Monday) 11:37
What damage with 40D/50D with 100-400 L IS and Kenko 300 DG 1.4X
Maxdave
Gallery: 49 photos
Oct 26, 2009 11:37 |  #1
I am contemplating buying a 100-400 f/4.5-5.6 L IS to go with my 40D, 50D, and my Kenko 1.4X DG300 TC. I successfully use the TC on a 70-200 f/4 L IS and a 85mm f/1.8, however, I realize these lenses are within the autofocus maximum aperture limits of the 40D and 50D, while my projected purchase is not.
I am aware that unless I tape the pins of the TC, this lens will not autofocus using the TC. I am also aware that the autofocus will not function as well as when used to Canon requirements if I tape the pins.
My question is, if I do tape the pins, and attempt to force the lens to try to autofocus, what PHYSICAL damage can result to the lens or camera bodies, and how likely is that damage? Will there be obvious signs that damage will occur if the combination is continued to be allowed to either attempt to, or achieve autofocus? Will I get time to stop, and revert to manual focus before damge occurs?
Maxdave
5D3,1D4,S90,6S&Moment Lenses,Hero4Silver,GPS​-E2,2x580EX,430EX,90EX,​EF16-35L f/4 IS,Samy SYTS24-C 24TS,EF24-105L IS,EF50 f/1.4,EF70-200 f/4L IS,EF300 f/4L IS,EF100-400L I IS,Kenko DGX 1.4X,Canon 2X TC Mk II, RRS&Pro-Media L-Brackets,Manfrotto MHXPRO-3WG & Roller 50,Sirui 306&K-20,Giottos MT-7371&MH-3300,Velbon ElCarmagne 530,CamRanger,Phottix&​Canon Remotes,Lowepro Backpack,ThinkTank Retro 20&Modular System,OpTech straps,Lexar/San Disk Cards
krb
Oct 26, 2009 11:39 |  #2
No risk of physical damage at all.
-- Ken
Gear list
Neilyb
Gallery: 23 photos
Oct 26, 2009 13:21 |  #3
Even taping the pins either body will not work....maybe occasionally, my 50d doesnt despite the 5D working fine. Would not consider it on 40 or 50d if you want AF.
http://natureimmortal.​blogspot.com (external link)
http://www.natureimmor​tal.com (external link)
krb
Oct 26, 2009 14:29 |  #4
Neilyb wrote in post #8898026 (external link)
I've had it work on the 40D so long as conditions are optimal. Full daylight, decent contrast between subject and background, and plenty of time to wait for focus before taking the shot.
-- Ken
Gear list
pwm2
"Sorry for being a noob"
Oct 26, 2009 14:35 |  #5
At least daytime, it works well with my 40D and either 1.4x or 2x TC. Because of the loss of IQ, I haven't really tested how my 40D likes the two TC stacked. I seem to remember that I probably had to use MF even in good light but it was a couple of years since I made very cursory tests.
wimg
Oct 26, 2009 14:41 |  #6
The Kenko when taped works reasonably well with regard to AF, provided it isn't too dark or contrast isn't too low. It actually works quite a bit better than the Canon extenders, which make AF hunt significantly more when taped than does the Kenko. AF is slower however than it si without the converter.
You could also try a non-reporting converter, like the Tamron-F AF Tele-converter 1.4X C-AF1 MC4, but you need to be aware that IQ-loss is a little higher than with the Kenko.
Kind regards, Wim
Maxdave
Gallery: 49 photos
Oct 27, 2009 07:55 as a reply to  @ wimg's post |  #7
Virtually all my intended use for the 100-400 & 1.4X TC on my 40D/50D will be in "good" light.
So, since no one has mentioned differently, I would have to assume there is no question of physical damage due to focussing issues. Is that correct?
Maxdave
krb
Oct 27, 2009 08:31 |  #8
Maxdave wrote in post #8902850 (external link)
My answer to this question is the very first response in the thread.
-- Ken
Gear list
pwm2
Oct 27, 2009 13:26 |  #9
No. You will not damage the lens if using it in an environment where light and contrast is enough for the AF to work.
It isn't directly dangerous, but you will increase the wear on the lens if you use it in an environment where it will constantly hunt for focus. But this is normally a self-solving problem. If the lens is hunting for focus, you will either get too frustrated and remove the TC or switch to MF - possibly with live view zoomed to max.
Neilyb
Gallery: 23 photos
Oct 27, 2009 14:20 |  #10
krb wrote in post #8898461 (external link)
I have had the 300 2.8 plus 2x and 1.4x stacked work in damn good light on the 50D....but never the 100-400 :(
I never heard of anyone wearing out a USM focus motor...
pwm2
Oct 27, 2009 14:25 |  #11
Neilyb wrote in post #8905053 (external link)
The motor itself is probably quite hard to wear out unless you overheat something. But the motor is moving mechanical parts and having the lens constantly hunt will result in a very significant increase in amount of mechanical movements per taken photo in relation to "normal" use.
Maxdave
Gallery: 49 photos
Oct 27, 2009 17:10 as a reply to  @ pwm2's post |  #12
Thanks for the information guys!
Maxdave
DANATTHEROCK
Oct 27, 2009 18:41 |  #13
I just got the Canon 1.4x TC myself. It will arrive tomorrow in fact. Read up on it extensively lately and sounds like what is said before me, on my 40D in good light and high contrast scenes, it will achieve AF with the pins taped on the 1.4x TC. I have heard it will be slow at times, hunting. So in low light or low contrast, MF will likely be the best bet. Just in case you would benefit from a pic, below is one I found of the pins being taped on the Kenko 1.4x TC.
IMAGE: http://farm4.static.flickr.com/3526/4048637387_99533c5dce_o.jpg
Canon 5D Mark II & 50D with 17-40, 24-105, 100-400, 50 f/1.4, 100 f/2.8 macro, and 1.4TC
FEISOL CT-3442 (ARL) tripod w/ Photo Clam 40-NS ballhead:lol:
pwm2
Oct 27, 2009 18:56 |  #14
Use tape that don't leave glue on the contacts to make it easy to use the TC with or without the tape. Document tape works well.
It is easy to remember what pins to tape, since it is the three extra pins that are not available on the camera body.
hollis_f
Oct 28, 2009 05:25 |  #15
pwm2 wrote in post #8905081 (external link)
When I tried this my patience wore out long before the USM would.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
3,056 views & 0 likes for this thread, 7 members have posted to it.
1040 guests, 106 members online
