Thread started 04 Jun 2005 (Saturday) 00:41
TIFF to JPEG "Action" or "Batch"??
Feihung08
Jun 04, 2005 00:41 |  #1
Anyone got a good 'action' or easy way to 'batch' convert TIFF's to highest quality Jpeg's?!?! I've tried to create my own action for this but can't figure out the "name" change issue. It always uses the same name so it constantly overwrites each conversion file.
I'm using PS CS.
Help!!
Canon 80D | Tamron 28-75mm | Canon 50mm 1.8 | Canon 430 EX | LensBaby 2.0
MattyB
Jun 04, 2005 03:16 |  #2
i played around with those automate things once.
i ended up converting every picture on my computer into a thumbnail and another copy of that orginal. which was well over 4000
i sat up alllll night clicking "ok" when it picked up a gif image
about 4 hours into it my brother came in, i explained. he hit the 'esc' key and it stopped...
i could've cried right then and there.
Matt Bennell
Camera: Canon EOS 80D DSLR Black
Extras: 18-55mm, 10-18mm, Tripod, ND8
Field: These days you'll likely be seeing plenty of Nature and Landscape posts :lol:
New Site In Progress -> bennell.co.nz (external link)
Feihung08
Jun 05, 2005 02:59 as a reply to  @ MattyB's post |  #3
LOL!!
I know what your talking about! Luckily it never happened as bad as that for me, but I feel your pain! I guess no one here knows any solid solutions to this since no one's responded though. Damn...........guess that means I have to figure it out on my own. :cry:
tim
Light Bringer
Jun 05, 2005 05:54 |  #4
In CS2, you use File -> Automate -> Image Processor. It's not in CS. CS2 integrated "Dr Browns Image Processor", which you can get for CS here (external link). It'll batch convert whatever to whatever. The other way is to create an action, and set up the batch processor like the attached image - ie check the "override save as" check box. I haven't figured out how to use "save for web" in an action yet, so I don't. Hope that helps, both methods should work, I use both for different things :)
Feihung08
Jun 06, 2005 17:18 as a reply to  @ tim's post |  #5
That's it! I gotta get CS2 then!
Sorry it's taken so long to get back to you Tim.......SUPER busy over here!
And I've been staying away from the "override save as" check box because my last action is to "save as", but maybe if I use this it will create different 'names' instead of overwriting the same ones!
Thanks!
tim
Light Bringer
Jun 06, 2005 17:20 |  #6
Nah you don't need CS2, and yes, "override save as" is so it saves with a unique file name rather than saving over the top of each file. The part of the dialog underneath that box lets you specify the file name to use.
Feihung08
Jun 06, 2005 17:44 as a reply to  @ tim's post |  #7
Cool.......I'll wait on the CS2 then........I need a processor upgrade more than anything first!
And I feel so dumb! I never checked that box but I always try and set up a good naming convention using those drop down boxes! DOH!
tim
Light Bringer
Jun 06, 2005 18:03 |  #8
I had the advantage of reading this book (external link), which is great for RAW and CS workflow.
Feihung08
Jun 07, 2005 00:25 as a reply to  @ tim's post |  #9
Man, you didn't waste any time getting into CS2 did you! I now put that book in my Amazon wish list too!
tim
Light Bringer
Jun 07, 2005 02:50 |  #10
You'd be better off putting it on a credit card ;) I actually have the CS1 version of the book, Amazon changed what the link points at for some reason. CS2 was pretty trivial to pick up without a book.
SWPhotoImaging
Joined Nov 2003
Jul 17, 2005 08:33 |  #11
I have PSCS2 (v9) on a PC, and there is no selection for "Image Process" under File -> Automate on my system. Is this a snap-in you downloaded? Is it an "extra" you have to locate on the CD and install separately?
SWPhoto-Imaging
SWPhotoImaging
Joined Nov 2003
Jul 17, 2005 17:24 as a reply to  @ SWPhotoImaging's post |  #12
I have since located the "Image Processor" in my CS2 menus. On mine, it is an option you reach by starting in Bridge, selecting the file(s) you want to process, then "Tools -> Photoshop -> Image Processor.
I can't find it anywhere within CS2, only via the Bridge.
SWPhoto-Imaging
tim
Light Bringer
Jul 17, 2005 17:28 |  #13
Look under file -> scripts in photoshop.
SWPhotoImaging
Joined Nov 2003
Jul 17, 2005 17:40 as a reply to  @ tim's post |  #14
AHA!
I was misled by an earlier post, and looked under File -> Automate.
Now, there is something I can't seem to make this tool do.
It does fine at taking an entire directory of .TIF images and making a new directory of .JPG versions of all the files, and can even constrain the maximum pixel dimension (long side), change color space to sRGB for web viewing, and also adds my copyright notice to the exif.
This is all FANTASTIC!
What I can't seem to make it do is to also make the ppi go from 240 to 72 for web viewing. I figure a full-sensor image would end up about 8" wide at 72 ppi and 600 maximum width, which should be great for web viewers to look at online, but not worth stealing/printing, because 72ppi is way too grainy. At 240 ppi, the 600 pixel-wide images are more like 3" wide.
Any ideas? Mayne I need a separate action first, to change all the ppi settings?
SWPhoto-Imaging
tim
Light Bringer
Jul 17, 2005 17:44 |  #15
I use an action if I want to change the size of the image. Don't worry about ppi, just worry about the number of pixels, almost everything ignores the ppi value.
7,210 views & 0 likes for this thread, 4 members have posted to it.
2113 guests, 96 members online
