You have a daughter. Your daughter takes horse riding lessons. The lessons in the colder months are held in the indoor arena.
The lighting is worse than "sucks", in fact, it should be a crime to call it lighting at all.
Your fastest lens is the 50mm f/1.8. However, you've gotten decent shots out of your 28-300mm IS L. Not spectacular, but good enough that you wouldn't be embarrassed to show them.
White balance, what is white balance? As soon as you even think about shooting in this arena, the white balance settings on your camera go to Tahiti. This place makes white balance look like rocket science, and I'm not a rocket scientist.
You can't set up lighting, mainly because you can't put it where it needs to be.
You can't use flash because direct flash won't help and the ceiling is basically beams and a roof, nothing to bounce off of. Plus, when your daughter is riding at the far end, you can't shoot flash that far. You can't even cheat and use a Better Beamer.
You can use your 50mm f/1.8, but even that isn't too good because you can only reach so far with 50mm, and the lighting is really bad, even f/1.8 doesn't help sometimes.
What do you do??
1.) Do you fight with what you have?
2.) Do you buy a new lens?
3.) Do you just take a PnS and shoot Auto, hoping that something nice will happen?
4.) Do you go and not take any pictures at all, and not capture the memories?
Any other choices?? What would you do?? Here are some example images, shot with the 50mm f/1.8.
![]() | HTTP response: 404 | MIME changed to 'image/gif' | Byte size: ZERO | PHOTOBUCKET ERROR IMAGE |
I was using one of my 20D bodies, I have a 40D, but other than shooting high ISO, I'm stuck with the same issues. The 40D shoots great at ISO1600, and I can work with the 50mm on that body, but only for closer shots. When she's halfway down the arena I'm stuck for distance. Cropping at ISO1600 and f/1.8 isn't really something I want to look at, it's ugly. I was thinking the 70-200mm f/2.8 IS L, because I think with that lens I can work a lot easier.
But, what would you guys do? Am I just being stupid, and these images aren't that bad, or should I be doing something else?? I can usually fix the WB in processing, but the overall image quality isn't where I want it to be. If it were just a little bit better and I wouldn't complain.
And for all you die-hards, shooting RAW won't help, I've done it numerous times and it doesn't give me any more room to work than I get shooting JPG.
