I have had someone look at my photos and say that they are all underexposed,
I have the Canon 50D and wondering if anyone else has the same thing, or what i may be doing wrong in order to correct it
jk.skinner Hatchling 4 posts Joined Oct 2009 More info | Oct 29, 2009 04:10 | #1 I have had someone look at my photos and say that they are all underexposed,
HybridUK Member 101 posts Joined Jul 2007 Location: Newcastle, UK More info | Oct 29, 2009 04:28 | #2 Post a couple of examples with exif detail intact please. Canon 5DMKII | Canon 50D | 24-70mm 2.8L | Canon 70-200mm f4L | Canon 50mm f1.8 | 580EXII | 430EX
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Oct 29, 2009 07:02 | #3 Easy test: Shoot an evenly lit blank surface - wall, paper, even a clear blue sky. Color doesn't matter, or focus for that matter. Set the exposure mode to P or if Av be sure the Exposure Compensation is set to 0. Now look at the camera's review histogram. You will see a sharp spike which should be a bit to the left of center - on a scale of 0 - 100 it should be at 40 or 45. If it is further to the left, the camera is underexposing. If it passes this test, your metering technique is probably at fault. Elie / אלי
HappySnapper90 Cream of the Crop 5,145 posts Likes: 3 Joined Aug 2008 Location: Cleveland, Ohio More info | Oct 29, 2009 09:04 | #4 jk.skinner wrote in post #8916340 I have had someone look at my photos and say that they are all underexposed, Thanks Cameras don't under expose, the photographer does that. Cameras are designed to expose for a neutral scene and certain colors dominating the scene can greatly throw off the exposure such as white and black.
Nov 09, 2009 02:21 | #5 HappySnapper90 wrote in post #8917255 Cameras don't under expose, the photographer does that. Cameras are designed to expose for a neutral scene and certain colors dominating the scene can greatly throw off the exposure such as white and black. I suggest learning to use exposure compensation on your 50D, which means not using full auto mode. Start by using P mode. And I suggest getting the book by Bryan Peterson: Understanding Exposure. Good luck. HappySnapper90
| Latest registered member was a spammer, and banned as such! 2815 guests, 133 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
