The IS doesn't seem to be activating. Is there something to check? I used to be able to hear it a little - no nothing. Did I set a custom function setting?
Thanks,
John
johnaengus Senior Member 494 posts Likes: 1 Joined Apr 2009 More info | Oct 29, 2009 20:17 | #1 The IS doesn't seem to be activating. Is there something to check? I used to be able to hear it a little - no nothing. Did I set a custom function setting? finndogphoto.com
crn3371 Cream of the Crop 7,198 posts Likes: 2 Joined Mar 2005 Location: SoCal, USA More info | Oct 29, 2009 20:22 | #2 You by chance didn't turn it off? At the very least, check the switch, perhaps cycle it a couple of times.
gasrocks Cream of the Crop 13,432 posts Likes: 2 Joined Mar 2005 Location: Portage, Wisconsin USA More info | Oct 29, 2009 20:39 | #3 Is it not working or just not making as much noise? Do some test shots at low shutter speed. GEAR LIST
Oct 29, 2009 20:47 | #4 I think I have it figured out. I was messing with the micro adjust focus and must have changed the custom function C.FN III. It was set on IS start. I changed it and it works. Hmmm. Oh, ya, I have a 5DII. Not sure what that setting is. I will have to explore more. finndogphoto.com
LightRules Return of the Jedi 9,911 posts Likes: 5 Joined Jun 2005 More info | Glad you got it figured out!
| Latest registered member is johntmyers418 1214 guests, 185 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
