Thread started 29 Oct 2009 (Thursday) 20:51
7d - moving the focus
NJBeacher
Oct 29, 2009 20:51 |  #1
Hey all. I just picked up a 7D. I had/have a 30D before this. I used CF4 to move the focus to the * button. On the 7D under CF4 and then Custom Controls, you can re-assign the buttons. However, the options for the * button only has a Metering AND AF start, not an AF Start only. Am I just looking at this wrong? Does it matter that the * button has both AF Start and Metering? Seems different from the way the 30D worked.
ccp900
Oct 29, 2009 22:45 |  #2
took me for a loop too to tell you the truth as i was also coming from a 30D. LOL.
anyways, yes set that to AF+Meter then set your shutter to AE LOCK. this should work the same way as the 30D moving focus to * button C.FcN.
[Sony A7R Mark 3 | Sony A7S | Sony Zeiss 16-35m f/4.0 | Sony FE 85m f1.8 | Sony FE 20m f1.8 G | Samyang 18m f2.8 | Samyang 45m f1.8 | Zeiss Batis 40m f2 | Sony FE 28m f2 | Sony Zeiss 55m f1.8 | Sony FE 28-70m f/3.5-5.6 | Helios 44-2 | Helios 44-3 | Nikon 105m f/2.5 AIS | Contax Zeiss Planar 50m f1.7 | Contax Zeiss Planar 100m f2 | Voigtlander Nokton 40m f/1.4 | Canon 24-105m f/4.0L | Canon 85m f/1.8 | Sigma 30m f/1.4 | Canon 10-22m f/3.5-4.5 | Canon 100m f/2.8 Macro USM | Canon 580 EX Ver 1.0]
NJBeacher
Oct 29, 2009 23:10 as a reply to  @ ccp900's post |  #3
Thanks for the reply. I was feeling really dumb for a while there. :)
ccp900
Oct 30, 2009 01:44 |  #4
happens to the best of us...cheers! now go out and take some pictures!!! LOL
apersson850
Obviously it's a good thing
Gallery: 35 photos
Oct 30, 2009 04:24 as a reply to  @ ccp900's post |  #5
It's not entirely correct either, or at least not the full story.
You can move focus to the * button, but there's no real reason, as the 7D has a separate button, AF-ON, for that. It has already been assigned the AF start + metering function as a default.
So what you need to do is to remove AF from the shutter. Set it to metering only, not AE lock.
The 7D has the * button as well, so AE lock you already have at the back.
The AF-ON button showed up already on the 40D, but the 7D allows for even more modifications to the buttons.
A combination like this may be interesting to some (everyday photography)[assuming One Shot AF and orientation independent AF point selection]:
Half-press: Metering and AF
AF-ON: Metering and AF with registerd AF point
*: Exposure lock
M.Fn: FEL
DOF preview: DOF preview
Or you may want this (track and field, with second AF setup for finish line shots):
[Now assuming Servo AF, +1 on AF tracking speed, AF/AF priority, Main point priority, single AF point, orientation dependent AF point selection]
Half-press: Metering only
AF-ON: Metering and AF with selected AF point
*: Metering and AF with registered AF point
M.Fn: AE Lock
DOF preview: [-1 AF tracking speed, AF/Drive priority, Continuous focus priority, AF point expansion]
There are many other possible combinations.
Anders
NPuter
Oct 30, 2009 08:02 |  #6
Is the registered AF point on the 7D a kinda preset af point (and mode?) that is assigned to a button
let me clarify:
Can I register a AF point for the * button to work independently from my "selected" af point that would be on the AF on button
also, do you select an af mode to go along with the registered point (say I am shooting with af expansion - can I make it so the registered point is always af spot?)
NPuter | flickr (external link) | instagram (external link)
5D Mark IV | 7D
16-35 f/2.8L II | 16-35 f/2.8L III | 24-70 f/2.8L II | 70-200 f/2.8L IS II | Sigma 30 f/1.4 | Sigma 50 f/1.4
Feedback
krb
Oct 30, 2009 08:19 |  #7
NPuter wrote in post #8923453 (external link)
Preset point. If you have registered the center point then when you are in spot, single point or expanded AF it will use the registered point. If you switch to zone it will use the zone that contains the registered point, which would be the center zone in this case.
let me clarify:
Like I said above, it always uses the current AF mode. But yes you can set up the camera so that the AF-On button is AF with the currently selected point and * is AF with the center point. Note that if you enable having different AF settings for horizontal vs vertical this makes the AF completely different for all 3 orientations. This includes AF mode so you might be in spot AF when horizontal and zone when holding vertical with the shutter towards the bottom and single point when vertical with the shutter on the top. It also includes the registered AF point, so you would need to register a point for all 3 orientations.
-- Ken
Gear list
apersson850
Gallery: 35 photos
Oct 30, 2009 16:39 as a reply to  @ krb's post |  #8
In addition to what krb stated above, you can also register a whole record of AF settings to either the depth of field button or to an AF stop button on the lens, provided you have any of these expensive telephoto lenses that are equipped with one. The EF 300 mm f/2.8L IS USM is one example.
These settings include
  • AF mode
  • Servo tracking sensitivity (C.Fn III-1)
  • Focus/Release priority (C.Fn III-2)
  • AF tracking mode (C.Fn III-3)
The registered and selected AF point(s) remain the same. Note that you have to keep the DOF button pressed for these alternative settings to be valid. When holding the camera vertically (trigger up), I find that I can press that button with my little finger and still use the zoom ring, but in horizontal mode, it's not very convenient.
Even if you have different AF settings for different camera orientations, the setting you make for the DOF button is the same, regardless of orientation.
Anders
2,002 views & 0 likes for this thread, 5 members have posted to it.
1282 guests, 178 members online
