In the Preferences Section, under the Tab "View settings" what numbers would you enter for Highlight/Shadow Alert?
I use 255 and 0 for Highlight and Shadow respectively, but wonder if a member has a different idea (and setting).
Maxdave
Maxdave Goldmember More info | Oct 30, 2009 14:16 | #1 In the Preferences Section, under the Tab "View settings" what numbers would you enter for Highlight/Shadow Alert? 5D3,1D4,S90,6S&Moment Lenses,Hero4Silver,GPS-E2,2x580EX,430EX,90EX,EF16-35L f/4 IS,Samy SYTS24-C 24TS,EF24-105L IS,EF50 f/1.4,EF70-200 f/4L IS,EF300 f/4L IS,EF100-400L I IS,Kenko DGX 1.4X,Canon 2X TC Mk II, RRS&Pro-Media L-Brackets,Manfrotto MHXPRO-3WG & Roller 50,Sirui 306&K-20,Giottos MT-7371&MH-3300,Velbon ElCarmagne 530,CamRanger,Phottix&Canon Remotes,Lowepro Backpack,ThinkTank Retro 20&Modular System,OpTech straps,Lexar/San Disk Cards
gooble Goldmember 3,149 posts Likes: 1 Joined Jul 2006 Location: Mesa,AZ More info | Oct 30, 2009 14:36 | #2 When I used DPP I left it at default. The only reason you'd want to change them is if you want to see when tones are approaching total black or white. That's up to your preferences
Player9 Senior Member 658 posts Joined Mar 2007 More info | Oct 30, 2009 16:02 | #3 I changed mine to make 6 the number for shadows and 250 the number for highlights. If you print a lot, it helps make sure that the printer/paper combination can handle the dynamic range of the image. RP, 60D, RF 24-105mm f/4-7.1 IS, RF 35mm f/1.8 IS, RF 50mm f/1.8, EF-S 10-22mm f/3.5-4.5, EF-S 18-135mm 3.5-5.6 IS, EF-S 55-250mm f/4-5.6 IS, Tamron 17-50mm f/2.8, EF 28mm f/1.8, EF 50mm f/1.8, EF-S 60mm f/2.8 macro, EF 85mm f/1.8, El-100, 430ex, 220ex, Alien Bee B400 (2), Alien Bee B800 (2)
| Latest registered member is semonsters 1040 guests, 105 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
